Honda Fit Honda Fit (Jazz)
automatic k20(Base Acura RSX auto) Swap??
Old Jun 2, 2007 | 03:39 PM
NCintegraLS's Avatar
Default automatic k20(Base Acura RSX auto) Swap??
I was wondering if anyone knew if this can be done on an Automatic Sport Fit..........I was thinking of doing the base model automatic k20 swap in the fit if it can be done???
Old Jun 3, 2007 | 09:41 AM
JchanFTW's Avatar
As quickly as people are going to be impressed with your K20 swap, they'll be just as quick to **** on your car for being an automatic.
Old Jun 3, 2007 | 11:16 AM
NW Classic Honda's Avatar
Default Re: (JchanFTW)
Ha ha so true!
Old Jun 3, 2007 | 02:34 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: (jdmda7)
there is no way an automatic k-series transmission will fit in the honda fit without extensive modifications to the frame rail
the k-series manual transmission already sits MILLIMETERS away from the frame rail, the automatic transmission casing is considerably bigger than that manual transmission
Old Jun 3, 2007 | 04:19 PM
eL's Avatar
eL
Default Re: (n1_98whp fit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_98whp fit &raquo;</TD></TR><TR><TD CLASS="quote">there is no way an automatic k-series transmission will fit in the honda fit without extensive modifications to the frame rail
the k-series manual transmission already sits MILLIMETERS away from the frame rail, the automatic transmission casing is considerably bigger than that manual transmission</TD></TR></TABLE>
I think someone's working on it on another board.
Old Jun 3, 2007 | 05:15 PM
JDMchris.com's Avatar
someone was talking about it on fitfreak, saying they were almost done with it. i think its BS
Old Jun 4, 2007 | 10:14 AM
n1_egsex's Avatar
* B A N N E D *
Default Re: (JDMchris.com)
Well not saying it wont work, but you'd have to compromise a huge part of the frame rail just to get it to fit. Plus if you're not getting race mounts (which are stiffer, less engine/tranny movement), you'd need even more space just to allow room for vibration when you get on the throttle and shift.
Old Jun 7, 2007 | 10:39 PM
eL's Avatar
eL
Default Re: (cooch69daddyxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cooch69daddyxx &raquo;</TD></TR><TR><TD CLASS="quote">y would anyone in their right mind want an automatic k20 swap in the first place?
If ur gonna do the swap ***** up and learn to shift a damn car</TD></TR></TABLE>
For the same reason someone would buy an Automatic RSX or an automatic Fit. They don't feel like shifting.
Old Jun 8, 2007 | 01:20 AM
07ssmfit916's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">For the same reason someone would buy an Automatic RSX or an automatic Fit. They don't feel like shifting.</TD></TR></TABLE>
maybe they could rig up the paddle shifters to work with the automatic rsx tranny.. that i would like to see..
Old Jun 8, 2007 | 08:46 AM
ZacCarter's Avatar
Default Re: (07ssmfit916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 07ssmfit916 &raquo;</TD></TR><TR><TD CLASS="quote">
maybe they could rig up the paddle shifters to work with the automatic rsx tranny.. that i would like to see.. </TD></TR></TABLE>It's all controlled by the ecu. That will never happen unless you spend serious coin.
Old Jun 11, 2007 | 07:17 PM
brian g's Avatar
Default Re: (JJSpecTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning &raquo;</TD></TR><TR><TD CLASS="quote">there is no way an automatic k-series transmission will fit in the honda fit without extensive modifications to the frame rail
Word. Of course that may not stop someone from trying.
brian g
Old Jun 11, 2007 | 08:12 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: (Ethan2000ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ethan2000ls &raquo;</TD></TR><TR><TD CLASS="quote">seems kind of like a pointless swap especilly since its a base k20 vtec's only on the intake cam and not worth it. learn to drive clutch</TD></TR></TABLE>
Just because someone wants to use the automatic transmission doesn't mean they can't adapt it to the K20A2 or the JDM ITR K20A.
NCintegraLS
Honda Fit
Dec 22, 2008 06:47 PM
donaldmejr
Honda Fit
Apr 23, 2008 05:49 PM
mmmsushi
Honda Fit
Feb 8, 2006 03:41 PM
thrty8street
16
Oct 25, 2005 05:08 PM
