WTB: Koni parts, the ring that goes above the C-ring.
I need four. These are the rings that go above the C-rings. The C-rings are the ones that go in the grooves, the ones I need are the rings that go on top and encircle the C-clips. If you have Koni's and use a Ground Control kit, you do not need the rings that I need. Thanks.
