94 EX brakes front assembly fit on my 97 hatch?
i was doing some searching and i thought everything between the eg and ek chasis was interchangable. Well brake wise.
My friend is bringing over complete front brake/rotor/spindle so on from an EG with LCA and sway bar.
i made a thread a while ago about putting a front sway bar on my ek hatch and to my understanding as long as i used an EX front lca from a 92-00 civic i was able to use the LCA and front sway bar on my 97 Hatch.
when i was doing some searching on brake compatibility i read that this isnt so? that the LCA wrong fit unless i take out the whole rear subframe and put in the EG subframe.
so yes or no EG EX LCA/Sway/Brakes/Rotors/spindles fit on my EK hatch.
thx...
yes i searched which lead me to this question.
https://honda-tech.com/zerothread?id=1513752
i also didnt see any 92-95 civics on this page.
thx...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ698 »</TD></TR><TR><TD CLASS="quote">yes but keep your LCA.otherwise I think you you gave to swap out the subframe.
but thats the thing. stock DX front LCA do not have mounting points for a front sway bar.
well the thing i traded a wrecked crx shell for parts.
one of those parts include complete front front end assembly which includes rotors, caliphers, lca, spindles, front sway bar with all endlinks and brackets...
if it doesnt fit then i have no use in them thus i need other parts for the trade.
i know suspension techniques offer a front sway for cars who did not come OEM with a stock front.
Im pretty sure the Lca's wont bolt up.I might be wrong though.My buddy swaped his subframe to use eg swaybar,but thats for his k swap
So im pretty you have to do the same.If you want a front sway just get 99-00 Si Lca's with sway bar.thats a direct bolt on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ698 »</TD></TR><TR><TD CLASS="quote">Im pretty sure the Lca's wont bolt up.I might be wrong though.My buddy swaped his subframe to use eg swaybar,but thats for his k swap
So im pretty you have to do the same.If you want a front sway just get 99-00 Si Lca's with sway bar.thats a direct bolt on.</TD></TR></TABLE>
ya i konw about the EM1 working, but they are hard to find
plus the eg were on hand with trade.
oh well.
i got it confused what it was is
EM1/CTR= you can only use their sway
92-00 can use any sway but the EM1/CTR
for some reason i just thought it was teh LCA that worked too. oh well.
So im pretty you have to do the same.If you want a front sway just get 99-00 Si Lca's with sway bar.thats a direct bolt on.</TD></TR></TABLE>ya i konw about the EM1 working, but they are hard to find
plus the eg were on hand with trade.oh well.
43MA
Dec 13, 2003 11:16 AM
