90-93 DA cluster diagram help
Old Jun 2, 2007 | 09:15 AM
sick stew's Avatar
Default 90-93 DA cluster diagram help
I've installed a cluster from a 91 integra DA into a 90 civic std hatchback. The DA cluster came with a small green clip that has a red, red/black, black, and yellow wires. The civic cluster had a small blue clip with a yellow, yellow/black wires. I can't seem to figure out where these two wires go. I've looked at all posts and none of them seem to mention the small blue/green clips. Should i just ignore these two wires?
Old Jun 2, 2007 | 10:47 AM
gibsanez's Avatar
Default Re: 90-93 DA cluster diagram help (sick stew)
Is it the small one on the top of the middle of the cluster? If so, ignore it.
Old Jun 2, 2007 | 11:19 AM
sick stew's Avatar
Default Re: 90-93 DA cluster diagram help (gibsanez)
Yeha, that's the one. I'm curious as to what those do
Old Jun 2, 2007 | 11:48 AM
gibsanez's Avatar
Something to do with cruise control or something equally as useless. Both my DA clusters have ran fine with them unplugged.
Old Jun 2, 2007 | 04:22 PM
sick stew's Avatar
The reason i ask is because everything on the DA cluster lights up except i get no response from the speedometer. Also, my turn signals don't work. They light up when the hazard lights are on though. I've researched about this and read something about a flasher/relay that's located under the dash. Any one have any other suggestions?
Old Jun 3, 2007 | 06:30 AM
gibsanez's Avatar
The speedometer is cable driven, it should be the cable with the big white clip that plugs right into the back of your speedo.
Old Aug 4, 2007 | 09:29 AM
jweeks's Avatar
either of you guys have the pin out diagram for installing a da cluster into an ef?
bbarbulo
May 19, 2016 02:58 AM
michael-crxsi
Mar 8, 2010 07:16 AM
95gainfla
19
Apr 2, 2009 05:49 AM
cbrf-3
Oct 3, 2004 06:37 PM
