Tempratures effect on power output
Old Jun 2, 2007 | 07:37 AM
EJ8 GSR-T's Avatar
Default Tempratures effect on power output
So in jan, i got my car tuned and it made about 250whp, now yesterday i had it done again and made around 220. Frist tune was in about 50* weather and yesterday was about 90*. Is there a such thing as a conversion table to reference this stuff with?
Old Jun 2, 2007 | 01:18 PM
Padawan's Avatar
Darth ModerVader
Default Re: Tempratures effect on power output (EJ8 GSR-T)
Here is the SAE J1349 JUN90 correction factor formula. There are also others, but it should give you a rough estimate:
This site also has a calculator that uses the same formula: http://www.ajdesigner.com/phph...f.php
Old Jun 2, 2007 | 01:55 PM
NJIN BUILDR's Avatar
The dyno software should have a correction factor for air conditions.But correction factors can only go so far.Was it the same dyno and operator?
Old Jun 2, 2007 | 05:27 PM
civicstar's Avatar
Default Re: Tempratures effect on power output (NJIN BUILDR)
yeh i agree, but if it was on a roller dyno (like dynojet). There are more factors. I tuned my car one day and made 219 whp (all motor) and i adjusted the position of the car, it was off by alittle bit and it made 225. i let it sit for a few minutes and ran it agian without any changes and it made 231. There are so many factors like if the car is well aligned and the tires (if they are warm or cold - tire pressure)
doood
11
Jun 25, 2010 11:49 AM
DA_JDM
Jun 3, 2007 08:21 AM
crawlin
Aug 25, 2006 09:44 AM
crdcz03
Sep 11, 2005 07:44 PM
