Suspension & Brakes Theory, alignment, spring rates....
koni/nuespeed
Old Jun 2, 2007 | 06:08 AM
LOWDWN's Avatar
Default needa be slammd ek sedan...
got nuespeed race and koni yellows fitted to ek sedan.
i got perches re-grooved and its tukin tyre all round but sittin on bumps, question is...
do the ground control tophats in effect just shorten shock or increase travel??
cheers
sam.
Modified by LOWDWN at 7:04 AM 6/3/2007
Old Jun 4, 2007 | 12:10 AM
LOWDWN's Avatar
Default Re: needa be slammd ek sedan... (LOWDWN)
up
Old Jun 4, 2007 | 10:19 AM
blinx9900's Avatar
they increase travel, go get you some!
Old Jun 4, 2007 | 10:25 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I'm pretty sure you can NOT use GC top hats with stock-style springs (i.e. regular lowering springs). You would need to fab up some DIY extended top hats using your stock top hats. There's a thread on H-T somewhere showing how to do that (welding is required).
Really the only thing that extended top hats do is allow the bump stop to sit up higher on the shaft and allow a little more shock travel before bottoming out. It does not allow any more actual suspension travel, i.e. the upper control arms will still hit the shock towers if you're not careful.
Old Jun 4, 2007 | 10:29 AM
blinx9900's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Really the only thing that extended top hats do is allow the bump stop to sit up higher on the shaft and allow a little more shock travel before bottoming out. It does not allow any more actual suspension travel, i.e. the upper control arms will still hit the shock towers if you're not careful.</TD></TR></TABLE>
correct you are.
Old Jun 9, 2007 | 12:18 PM
blaak-crx's Avatar
Yup, I got that problem right now: upper control arm hitting the chassis
gabstar
Suspension & Brakes
Sep 19, 2006 01:34 PM
RDLIN-IT
Dec 1, 2005 06:48 PM
slowacura
Dec 13, 2003 11:25 PM
nickgomez
Oct 6, 2003 09:31 PM
Audipwr1
19
Apr 26, 2003 01:24 PM
