Fan comes on often??
Yep, I noticed my fan start and stop 3 times while warming up in about 60 seconds. Temperature outside was about 10 degrees C. Fan would start and go for about 15 seconds, then stop for a few seconds, start again etc. ...
I noticed last week that when the ventilation is on defrost or half defrost/half feet the a/c starts automatically.
Thats why the fan was starting up even when it was cold outside and the motor cold also.
That's correct. The HVAC system is setup so that when you twist the **** to either half defrost, or full defrost, the AC will come on with it. The light on the AC button does not light up, but the AC is definately on.
Here's a post on how to unplug it so that the AC only comes on when the button is pressed:
http://www.fitfreak.net/forums....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dai »</TD></TR><TR><TD CLASS="quote">That's correct. The HVAC system is setup so that when you twist the **** to either half defrost, or full defrost, the AC will come on with it. The light on the AC button does not light up, but the AC is definately on.</TD></TR></TABLE>
Why would Honda not have the A/C button light up? Not cool.
