Front end knock?
Old Jun 2, 2007 | 04:48 AM
rcar97's Avatar
Default Front end knock?
Searched throughly. All help appreciated. When I give it gas in 1st I get a single knock and then if I let off I get the same knock? On/off knock/knock? One of my upper balljoints was gone so I changed both sides and didn't help at all. Its on the drivers side where I had the bad upper BJ What could it be? lower BJ? axel? shock? bearing? My mounts all feel pretty tight and the hydraulic one isn't leaking. Thanks alot
Old Jun 2, 2007 | 05:41 AM
DontBlink's Avatar
Default Re: Front end knock? (rcar97)
my upper control arm where they bolt through the strut tower were blown out and made a "knocking" sound from slideing back and forth when you got on and off the gas. with the car jacked up and the suspension just hanging there everything seemed tight. so i sat the front of the car on blocks and let it down, with the weigh of the car where it should be, i could easily grab the upper control arm and slide it back and forth from under the car.
Old Jun 2, 2007 | 05:47 AM
rcar97's Avatar
Default Re: Front end knock? (DontBlink)
Changed both upper control arms and they are pretty tight. No movement side to side whatsoever. ????
Old Jun 4, 2007 | 06:14 PM
01-0338R's Avatar
Have the same thing happening to me. Driving me nuts!!!
jonyi27
Mar 23, 2014 07:59 AM
Kris's turbo
Dec 1, 2012 06:38 PM
EF9Infantry
Nov 21, 2010 09:33 PM
this_guy
Nov 30, 2008 10:29 AM
satsilprelude
Dec 10, 2006 11:38 AM
