Coolant water Drain too fast...
Old Jun 1, 2007 | 05:39 PM
accord23's Avatar
Default Coolant water Drain too fast...
I have a 95 honda accord, what's wrong with it is that everytime I added coolant water...a week or two later, the water keep running low?...any thoughts?
Old Jun 1, 2007 | 06:02 PM
fleetw00d's Avatar
Default Re: Coolant water Drain too fast... (accord23)
You've got a leak somewhere, either externally (hose, radiator, heater, etc) or internaly (head gasket). Is it running hot? Are you adding to the overflow tank or directly to the radiator? If you let it go long enough, will the level in the radiator conintue to drop or does it only empty the overflow tank? Any evidence of water in the oil (it would look brown and foamy)?
Old Jun 1, 2007 | 08:58 PM
accord23's Avatar
Externally, there are no coolant water that would be visibly coming out the radiator. Internally, I'm not sure but I was told that when you pour coolant water into the radiator,if there are bubble or foam coming out the radiator cap top, means that your head gasket is bad. And that seems like not the problem either. As for water going inside the engine, NO, that's not the case either. Another question that I wanted ask is that if this continue..what's the worst can happen? Any other thoughts...
Old Jun 2, 2007 | 10:01 AM
Bruce Banner's Avatar
happens in my car too.
after like 3-4 weeks the extra resevoir tank will be empty
mnaffay205
Nov 7, 2014 06:42 AM
DevonsHonda
Dec 20, 2013 05:40 PM
chota
Honda Civic (2001 - 2005)
Dec 30, 2012 08:19 AM
goowakjai
Aug 2, 2005 08:59 PM
