will the rims fit
Ok, I searched but all I came up with was info about lips....I probably put the wrong search words in. Will rims off a 1994 Jetta work on a 1988 Hatch or the other way around.
The bolt pattern will match but either the offset (how deep or how flush the wheel is) may be different and the center bore may be smaller or larger. Best way if you can is to test fit and make sure the wheel sits flush against the hub.
Cowtit
May 6, 2003 10:00 AM
