91 crx auto to manual swap problems
Old Jun 1, 2007 | 05:27 PM
superex87's Avatar
Default 91 crx auto to manual swap problems
Hey guys sooo
I have a 91 crx dx that i changed from auto to manual, it is throwing code 8 and 19
when i crank it over it will run for about 3 seconds then dies, It also has a distributor from an HF but has been repinned so that the wire colors match ( there are 2 blue wires that are not hooked to anything)
Is there anything else that needs to be done to the wires by the shifter , i have already wired the starting wire and the one that lets you get your key out of the ignition, does anything have to be pluged into these?
there is also 4 wires under the dash by the fuse box that all go into a yellow conecctor but i dont know where it plugs into, where does this go?
Thanks Ben
Old Jun 7, 2007 | 10:11 PM
z crx z vtec z's Avatar
Default Re: 91 crx auto to manual swap problems (superex87)
i did an auto to manual on my integra ..does the car say its in park when you turn it on? (the light on your cluster) if it does you need to loop the wires in order to trick the car into thinking its in drive. hope that can help
Old Jun 7, 2007 | 10:19 PM
obd1_crx's Avatar
if all you did was an auto to manual you didnt need to mess with the distributor. now if you swapped from dpfi to mpfi there is a lot more than the distributor wires to mess with.
Old Jun 8, 2007 | 07:30 AM
I CRX I's Avatar
this may sound like a pretty dumb question but have you made sure the car was in nuetral and that you push the clutch in before starting? the swap should be pretty straight foward so if your messing with wiring (other then the wires under the shifter) then that might just be were your porblem lays
Peruviann
Sep 11, 2007 09:58 AM
Vinceg99
11
May 5, 2003 05:40 AM
slow hatch
Dec 17, 2002 11:08 PM
elmalouno
Nov 3, 2002 02:25 AM
