Blox LCAs: How to hook up rear sway bar....??
I just got a set of Blox LCAs for my 99 GSR. I noticed that they dont have any holes in them for the rear sway bar. How are you guys hooking the LCAs to the sway bars?? I'm lost...thanks!
well what holes do i use??? There aren't exactly threadded holes nearby that i could just stick a bolt in...on the stock LCAs, there's a hole where a bolt threads.....nothing on here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">well what holes do i use??? There aren't exactly threadded holes nearby that i could just stick a bolt in...on the stock LCAs, there's a hole where a bolt threads.....nothing on here</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chinoty »</TD></TR><TR><TD CLASS="quote">Home Depot = Nuts / Bolts = DIY.....
Some times you got to think outside of the box.... </TD></TR></TABLE>
this guy just gave you the answer. You have to get a bolt AND NUT from home depot or whatever hardware store, and just do it that way. Its not too hard of a thing to figure out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racing rice »</TD></TR><TR><TD CLASS="quote">My understanding is that Blox sells endlinks that work. </TD></TR></TABLE>
BTW, I also bought the BLOX endlinks and they dont work. I've been using my OEM. If anyone has any pictures on this it would help out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue »</TD></TR><TR><TD CLASS="quote">
how is a bolt and nut going to work is there is no hole on the LCA for a swaybar end link?
i'm going to take a few pics of my LCAs later today or tomorrow and i'll have someone figure out where the bolt goes unless i can figure it out first....
I can't believe nobody else has used these before....
duh!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">
how is a bolt and nut going to work is there is no hole on the LCA for a swaybar end link?</TD></TR></TABLE>
there is indeed a hole for the endlink, i have the blox lca's with the speedtech bar.
duh!
i'm trying to visualize how all of this goes together in my head because i dont have any of the parts in front of me....please excuse my ignorance
Do you have any pictures because that would make this about 100x easier for me
Here U go!!! ALL YOU HAVE TO DO NOW IS "STICK IT IN THE HOLE", AND IF YOU CANT DO THAT, YOU REALLY GOT ISSUES....
BTW... you might need some washers to have it sit properly...
BTW... you might need some washers to have it sit properly...warning, i have those blox lca's and i just want you guys to know they SUCK ***!!!!!! the bushings cracked after 3 months
and i dont wanna here anybody say "did you install them correctly" cause i never had a set of stock bushings crack. BLOC LCA'S SUCK!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">perhaps it's the bushings that suck (and indeed polyurethane does suck for daily driving), and not the control arms themselves.</TD></TR></TABLE>
bushings are a part of the arm, i dont think anyone is going to change them out.
Mikes2000civicsi
Mar 27, 2008 09:02 PM
spock_rocker
May 23, 2004 06:43 AM
