front sway joint
okay because of the slammed drop ride height and abuse, the front sway bar poped out of the endlinks, looks like a rubber joint kinda. i was wondering if there are aftermarkets for the front and if it's an easy fix, the stock endlinks are still in the control arm just the rubber joint ripped.
Modified by teddy_dc2 at 5:26 PM 6/1/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 »</TD></TR><TR><TD CLASS="quote">need something like this...
WHERE TO GET SOMETHING LIKE THIS.. I HAVE THE SAME ISSUE ON MY SETUP WHEN I UPGRDE TO A TYPE R....PLEASE SHARE..
</TD></TR></TABLE>WHERE TO GET SOMETHING LIKE THIS.. I HAVE THE SAME ISSUE ON MY SETUP WHEN I UPGRDE TO A TYPE R....PLEASE SHARE..
all i found was the stud kits with bushings like the suspension techniques's but rather seems that design bolts vertically to the sway, the oem here seems horizontally.
which do you think would work better. a male or female rod end? if you went female you would need a bolt going from the bottom -> up
http://aurora.thomasnet.com/it...o=110
going to make some rear endlinks too by combining male & female
igo4bmx
Suspension & Brakes
Mar 19, 2006 10:15 AM
