can i swap doors from an ex to a dx?
Old Jun 1, 2007 | 03:52 PM
ohnoitsryan's Avatar
Default can i swap doors from an ex to a dx?
trying to get power windows/locks in my dx
i found a guy with two ex doors
can i just swap them in theory?
do all the harnesses coming out of the ex door have factory installed places to be plugged into to on my dx?
Old Jun 1, 2007 | 04:31 PM
satinsol's Avatar
Default Re: can i swap doors from an ex to a dx? (ohnoitsryan)
Just swap the interior panels dont swap the whole door
Old Jun 1, 2007 | 04:36 PM
JasonGhostz's Avatar
They use different connectors between the Door Harness and the Floor Harness. The EX uses a 25-cavity connector, vs the DX's 2-cavity connector.
Unless you want to do your own wiring into the Main Harness (remember, the Floor Harness won't have dead ends for you to connect to), you may need to get a different Floor Harness for your DX. This might lead to other undesirable results. In any case, you could try the Salvage Yards for the Connectors (both sides, on both sides) and/or the Floor Harness from an EX ($200 for a brand new OEM Floor Harness).
Good Luck!
JasonGhostz
illestsilek
Jul 8, 2008 12:00 AM
ek_b16
Jan 29, 2005 12:10 PM
