LS oil pickup same as GSR???
Old Jun 1, 2007 | 03:38 PM
homicydalboy's Avatar
Default Can you use a GSR oil pickup in an LS block???? HELP!!
Are they same or do they differ. I know that the b16 is different but is the ls different than the GSR. I have an LS block and thought that since I dont have the windage tray and pick up that I would use the B16 cause like the LS they dont have the block girdle like the gsr and type R. Yeah well that didnt work. The gsr one lines up but just wanna make sure it will all work.
This is the parts I have I have a b16 windage tray and pick up and a gsr windage tray and pick up what combo if any should I use???
Modified by homicydalboy at 7:44 PM 6/1/2007
Old Jun 1, 2007 | 05:46 PM
doood's Avatar
been there done that
Default Re: LS oil pickup same as GSR??? (homicydalboy)
gsr and ls pickups have different part numbers so im guessing they wont work
you're going to need a gsr windage tray and oilpan if you want to use it's pickup
Old Jun 1, 2007 | 06:43 PM
Default Re: LS oil pickup same as GSR??? (doood)
well the GSR pick us lines up perfect with the holes on the block to bolt right on. And for the oil pan I am running the moroso. I was thinking since I dont have a block gridle like the gsr's do to run a b16 windage tray cause they dont have the girdle either. The b16 oil pickup doesnt even come close. But the GSR it bolts up to all 4 mounting points and clears the pan and girdle. Any more input on this????
Old Jun 1, 2007 | 08:22 PM
bump for help!!!
Old Jun 2, 2007 | 11:56 AM
kevinz's Avatar
Maybe this can help: I have a gsr motor w/ a LS pan from moroso (old one) I have gsr windage tray and the ls pickup,,,,,BUT,,,,, the ls pickup didn't fit right,,,,, I had to cut Stock GSR bracket and weld it to the Morso LS pickup to work.. Hopefully I make sense, if not good luck.
Old Jun 2, 2007 | 12:48 PM
NJIN BUILDR's Avatar
I'm using a gsr pickup with my aluminum Moroso pan.Been working fine for the last couple years.
Old Jun 2, 2007 | 04:40 PM
Default Re: LS oil pickup same as GSR??? (NJIN BUILDR)
Found it out. The LS and the B16 pick up are the same. The long leg ones. The GSR and Type R are the same shorth leg ones. Same goes for windage trays. So if you are using an ls then you need a b16 or LS windage tray since neither of them have the block girdle. it all make sense now!!!
grant97teg
Feb 23, 2009 04:38 AM
nabin
Apr 5, 2008 07:52 PM
vtec4max
Dec 26, 2006 03:58 PM
11secEk
Mar 28, 2005 06:50 AM
SM 30 Hatch
Oct 7, 2004 04:12 AM
