Donut.'s Garage Sale
Originally Posted by donut.
[*]Okay so heres the deal. Let it be known, that this is already "the lowest I will go" price for these items.
[*]Please read the description before asking me something...PLEASE
vouches
https://honda-tech.com/zerothread?id=1453664
<FONT COLOR="purple">Autometer Air/Fuel Guage</FONT> - $30 Shipped
Pro-Comp Series (Ultra-Lite). Has Silver face. Used but in new condition.
[img][/img]
<FONT COLOR="purple">OEM Honda Bumper</FONT> - $125
[i]<u>KEVLAR LIP IS NOT FOR SALE</u>. This bumper is in like new condition and is 100% OEM Honda, not some replica and it fits like a glove. I shaved the license plate holes with urethane filler, no bondo. The bumper was then shot with primer (not rattle canned). The grill was masked with precision (no overspray). And finally, the foglight holes were cut out like factory (no hack job). This is ready to be shot any color you please. I can also include a used OEM Honda Lip for an extra $50 on top of my asking price. If you buy the bumper, lip, and foglights, I can give you some sort of package deal as well.
<u>AGAIN, THE KEVLAR LIP IS NOT FOR SALE</u>
<FONT COLOR="purple">JDM EG6 Foglights</FONT> - $225 Shipped
Real deal JDM Stanleys. Was holding on to these for about 2 years and just now, decided to part with them
These are mint and complete with the covers, harness, and switch. The foglight covers are primered because i had intentions on color matching them with my car. The power wire going to the foglights is cut (this is a very easy fix) but everything else is there. The plugs going to the fuse box are numbered to make it that much easier and the OEM relay is in tact and working. What more can you ask for
<FONT COLOR="purple">92-95 Civic Hatch Wing</FONT> - $5
This is a USDM wing. One of the corners is chipped
<FONT COLOR="purple">92 Civic Subframe</FONT> - $60
Includes OEM LCA's although there are no holes in the LCA's to mount a swaybar. The bushings are in good condition considering they are 15 years old. This is also a non power steering subframe. Ideal for K swaps in 96-00 Civics.
<FONT COLOR="purple">OEM Honda B-series Fan Switch</FONT> - $20 Shipped
Brand new, never opened, or used
<FONT COLOR="purple">SOHC Short Shifter</FONT> - $10 Picked Up or $17 Shipped
Pictured below on the <u>RIGHT</u>. Its annodized red. This came off my EJ1 back in 2004 when I first purchased it. It could be a Ebay shifter for all i know.
<FONT COLOR="purple">OEM Honda Windows</FONT> - $100 Pick-Up ONLY
Applications = 92-95 Civic Hatch or Coupe. Same conditions as above. Works out for you if your window was smashed by some dickless thief.
*pictured behind the windshields, sorry, im too lazy to take them out*
<FONT COLOR="purple">OEM Honda Doors</FONT> - $100 Pick-Up ONLY
Applications = 92-95 Civic Hatch or Coupe. Now, these are primered BARE doors (READY TO PAINT). They came off my EJ1 project that I never finished. There are absolutely no dents on these however, there may be slight waves but I assure you IF there are then they will be minimal. Cant get around it with these body style civics I tell you.
[img][/img]
<FONT COLOR="purple">RHD Conversion for 92-95 Civic Hatches/Coupes</FONT> - $350
I have 95% of everything you need to convert your car to RHD:
NOT PARTING ANYTHING OUT FROM THIS CONVERSION NOR WILL I SHIP IT.
I already drilled out the firewall (saves many hours)
power steering rack
CLEAN RHD black dash (bare, no electronics)
Pedal assembly (same as your U.S. ones)
steering column (has tilt option)
steering column support (chromed)
all necessary brackets to mount the support (all chromed)
2 side brackets that hold the dash and relays (all chromed)
hood popper lever
trunk release lever
complete interior harness/relays (cut where it runs along the door jamb)
throttle cable
BNIB RHD Option Audio Console
The bad (or may be good depending on how you look at it):
missing brake lines
missing heater and blower
welded all the holes on the firewall shut
grinded down all the studs on the firewall for the brake lines
missing wiper motor
Note: Chrome bar not included sorry
RHD Subframe
RHD Firewall
All the dash/column ****
Brackets that hold on the column/dash ****
RHD hood/trunk/gas cap release
Throttle Cable
RHD Pedals and dead pedal
RHD Signal stuff
RHD Harness
Where its cut
<FONT COLOR="purple">OEM EJ1 or EH2 Sunroof Motor</FONT> - $20 Shipped
Want your sunroof to open and close with no hesitation? You're looking at a motor thats perfect for you
<FONT COLOR="purple">Clutch thingy</FONT> - $5
I believe this is so you can go from a 10mm fitting to a 12mm fitting. It might even be a joke to try to sell this
<FONT COLOR="purple">SRS Computer and Impact Sensors</FONT> - $20
<FONT COLOR="purple">EJ1 Rear License Plate/Trunk Garnish</FONT> - $15
I have the rear license plate lights that go with this as well.
<FONT COLOR="purple">92-95 Civic Door Handles</FONT> - $20
Granada black with a little sanding marks but in great condition
<FONT COLOR="purple">Mounts</FONT> - $10
A/C bracket, Tranny braket, and rear Tranny mounts
vouches
[img][/img]
These are mint and complete with the covers, harness, and switch. The foglight covers are primered because i had intentions on color matching them with my car. The power wire going to the foglights is cut (this is a very easy fix) but everything else is there. The plugs going to the fuse box are numbered to make it that much easier and the OEM relay is in tact and working. What more can you ask for================================================== ==========================================
[img][/img]
power steering rack
hood popper lever
trunk release lever
throttle cable
missing brake lines
missing wiper motor
RHD Subframe
RHD Firewall
Throttle Cable
RHD Signal stuff
RHD Harness
Where its cut
<u>SOLD</u>
<FONT COLOR="purple">JDM ITR 4-1 Header</FONT> - <u>SOLD</u>. Thanks!
<FONT COLOR="purple">SSR MK3's</FONT> - <u>SOLD</u> to jdmef-9. Thanks!
<FONT COLOR="purple">Slim Radiator Fan</FONT> - SOLD to Coach Mcgirk on NWP. Thanks!
<FONT COLOR="purple">GSR Front Knuckles</FONT> - <u>SOLD</u> to jdmef-9. Thanks!
<FONT COLOR="purple">Narspec Shift ****</FONT> - <u>SOLD</u> to EKidd. Thanks!
<FONT COLOR="purple">JDM EJ1 RHD Floormats</FONT> - <u>SOLD</u> to SkankyEJ7. Thanks!
<FONT COLOR="purple">JDM Sidemarkers</FONT> - <u>SOLD</u> to babyS2K. Thanks!
<FONT COLOR="purple">92 Civic OEM Manual Window/Doorlocks</FONT> - <u>SOLD</u> to lreg on NWP. Thanks!
<FONT COLOR="purple">B-Series OBD0 Alternator</FONT> - <u>SOLD</u> to lek9l. Thanks!
<FONT COLOR="purple">OEM Front and Rear Windshields</FONT> - <u>SOLD</u> to blivic. Thanks!
<FONT COLOR="purple">JDM EG6 Headlights</FONT> - <u>SOLD</u> to xb on NWP. Thanks!
<FONT COLOR="purple">Apex'i VAFC-2</FONT> - <u>SOLD</u> to bart2546. Thanks!
<FONT COLOR="purple">SOHC B&M Short Shifter</FONT> - <u>SOLD</u> to mugen mj5. Thanks!
<FONT COLOR="purple">92-95 Civic Hatch Carpet</FONT> - <u>SOLD</u> to shrums. Thanks!
<FONT COLOR="purple">KJC License Plate Frame</FONT> - <u>SOLD</u>
<FONT COLOR="purple">B-Series Knock Sensor</FONT> - <u>SOLD</U>
<FONT COLOR="purple">EG/EJ1 Door Rubber seals</FONT> - <U>SOLD</U>
<FONT COLOR="purple">EG E-Brake</FONT> - <u>SOLD</u>
Modified by donut. at 9:00 PM 10/7/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donut. »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by born2lose »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jkeno112 »</TD></TR><TR><TD CLASS="quote">bump it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ==Catfish== »</TD></TR><TR><TD CLASS="quote">TTT</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ==Catfish== »</TD></TR><TR><TD CLASS="quote">TTT</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ==Catfish== »</TD></TR><TR><TD CLASS="quote">TTT</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ==Catfish== »</TD></TR><TR><TD CLASS="quote">TTT</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ==Catfish== »</TD></TR><TR><TD CLASS="quote">TTT</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KaaL »</TD></TR><TR><TD CLASS="quote">bump
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KaaL »</TD></TR><TR><TD CLASS="quote">bump
bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donut. »</TD></TR><TR><TD CLASS="quote">bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump bump </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM RHD eg6 »</TD></TR><TR><TD CLASS="quote">
