Suspension & Brakes Theory, alignment, spring rates....
Type R 22mm Sway Bar used with Comptech Rear Tie Bar??
Old Jun 1, 2007 | 12:28 PM
kcjohnnyboy's Avatar
Default Type R 22mm Sway Bar used with Comptech Rear Tie Bar??
I was thinking of getting the ASR rear subframe brace with the Type R sway bar but found out that you had to drill out one of the holes for a plate that ASR supplies. But, then I was also considering the Comtech Sway/Tie Bar Combo. If I got the Comptech rear tie bar for the combo instead of the sway bar with it and use a USDM Type R sway bar with it, will that work? or is there modification needed using oem parts for the sway bar?
TIA
Johnny
Old Jun 1, 2007 | 01:02 PM
TunerN00b's Avatar
Default Re: Type R 22mm Sway Bar used with Comptech Rear Tie Bar?? (kcjohnnyboy)
If you are going to use the Comptech tie bar, why not use the Comptech swaybar as well? It is stiffer than the ITR bar, and is adjustable.
Old Jun 1, 2007 | 01:10 PM
EK4civichatch's Avatar
Default Re: Type R 22mm Sway Bar used with Comptech Rear Tie Bar?? (TunerN00b)
I<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">If you are going to use the Comptech tie bar, why not use the Comptech swaybar as well? It is stiffer than the ITR bar, and is adjustable.</TD></TR></TABLE>
It's stiffer?? I didn't know that...
Old Jun 1, 2007 | 01:17 PM
both comptech and itr sway bar are 22mm but didnt know there was a difference in stiffness though
Old Jun 1, 2007 | 01:18 PM
just trying to go a cheaper route than buying the whole tie bar combo from comptech, and i rather have a black sway bar than a silver/gray one
Old Jun 2, 2007 | 07:22 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy &raquo;</TD></TR><TR><TD CLASS="quote">
just trying to go a cheaper route than buying the whole tie bar combo from comptech, and i rather have a black sway bar than a silver/gray one </TD></TR></TABLE>
The comptech is adjustable. I believe that the stiffest setting is stiffer than the ITR, I don't know by how much though.
Old Jun 2, 2007 | 08:03 PM
stumpyf4's Avatar
I'm running that exact setup, no issues. Big plus is no noise from the hemi-endlinks that Comptech uses. Also the hemi-endlink tend to seize or get sloppy in my climate.
I had to buy some hardware (screws, energy d-brackets) since the tie-bar I got from Comptech was bare.
Old Jun 3, 2007 | 01:52 AM
thanks for the comments but still want to know if it's still possible to use an integra type r sway bar 22 mm on the comptech tie bar using oem parts
Old Jun 4, 2007 | 03:11 PM
does anyone know? i might just have to call up comptech to see what they tell me
Old Jun 4, 2007 | 04:53 PM
stumpyf4's Avatar
Default Re: (kcjohnnyboy)
The answer is yes, I have a Comptech Tie Bar and ITR rear sway. I chose Energy d-brackets and bushing because they're cheaper than OEM stuff. Screws are generic. Found the link that gave me the idea.
http://integramod.tripod.com/p....html
Old Jun 4, 2007 | 05:13 PM
gottabfast's Avatar
that bar is the perfect bar/brace combo...unfortunately, I believe Comptech is closed...
Old Jun 4, 2007 | 06:04 PM
Default Re: (gottabfast)
They're open again..
Old Jun 4, 2007 | 08:13 PM
i was going to go with asr w/ type r sway or with comptech tie bar sway combo but found out asr requires drilling out a threaded hole limiting it to ever go back to stock again if i ever decide to do so. comptech does not require drilling i believe unless someone can confirm that. with the comptech tie bar added w/ a type r sway bar i can also probably save some extra money than buying the whole combo
Old Jun 4, 2007 | 08:17 PM
Default Re: (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">The answer is yes, I have a Comptech Tie Bar and ITR rear sway. I chose Energy d-brackets and bushing because they're cheaper than OEM stuff. Screws are generic. Found the link that gave me the idea.
http://integramod.tripod.com/p....html</TD></TR></TABLE>
thanks man
Old Jun 4, 2007 | 08:28 PM
just to make sure stumpyf4, it does not require drilling correct to install the comptech tie bar?
Old Jun 4, 2007 | 10:43 PM
.:Made in OC:.'s Avatar
if your putting the asr or beaks kit, there going to be drilling needed to enlarge holes or remove tac welds. Comptech is easy as bolting on.
Old Aug 7, 2007 | 11:22 AM
i guess comptech discontinued the tie bar combo for the integras. I just got off the phone with them just now
Old Aug 7, 2007 | 03:13 PM
nonsense's Avatar
There are some clones being made right now. RCrew makes one that is styled off of the comptech
Old Aug 8, 2007 | 12:51 PM
Default Re: (nonsense)
do they have a website I can check out that you know of?
Old Aug 8, 2007 | 05:46 PM
nonsense's Avatar
frito sells them:
http://www.myspace.com/guatness
or you can contact them direct
http://www.rcrewracing.com/
Old Aug 8, 2007 | 08:57 PM
thanks nonsense
Old Aug 9, 2007 | 01:03 AM
OC Geezer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gottabfast &raquo;</TD></TR><TR><TD CLASS="quote">that bar is the perfect bar/brace combo...unfortunately, I believe Comptech is closed...</TD></TR></TABLE>
A month or two ago that was true. But they're back. From what I know new management.
And yes it will work.
Old Aug 24, 2007 | 10:01 AM
beav's Avatar
ok what car are you putting this on?? asr parts do not require any drilling. im using the asr brace with the usdm itr bar on my 98 civic hatchback. everything was direct bolt on.
the comptec bar might be solid where as the oem bar might be hollow...but dont quote me on that.
personally i think the asr brace design will be more effective than the comptec brace. the sway is up to you...if you have an ek, you can use the ctr bar or the itr bar..they both work.
Old Aug 24, 2007 | 11:16 AM
Default Re: (beav)
asr & beaks i believe require drilling on both eg/dc chassis. Comptech is direct bolt on.
Old Aug 24, 2007 | 04:00 PM
Default Re: (beav)
it will be put on a dc chassis, and the asr brace requires minor drilling of one of the threads in the subframe so the metal plates they supply will bolt up correctly i believe. i know that comptech does not require drilling, that is why i would rather have that just in case i ever want to go back to stock.
