Suspension & Brakes Theory, alignment, spring rates....
SRR rear swaybar/tie bar combo help!
Old Jun 1, 2007 | 07:40 AM
Parker.'s Avatar
Default SRR rear swaybar/tie bar combo help!
I recently purchased some SRR rear lower control arms, rear sway bar and tie bar for my EK4. However when trying to replace the 10mm bolts for the rear lower arm that attach to the subframe i notice that they are slightly too short. I was wondering is it possible to just replace this original bolt with a longer high tensile bolt in order for me to fit my rear sway bar/tie bar?
I've also noticed that these standard bolts are splined on the bearing surface, is there any particular reason that Honda did this? Does it matter if the replacement bolts dont have these splines?
Any help is greatly appreciated!
Thanks
Old Sep 24, 2007 | 05:46 PM
sailingstu05's Avatar
Default Re: SRR rear swaybar/tie bar combo help! (Parker.)
Did you ever solve this problem? I just bought the same kit, and realized that I'm going to run into the same problem. I was hoping to just replace the bolts with longer high grade bolts, but finding 10mm X 1.25 pitch bolts that long in high grade steel seems impossible!
Did you find somewhere to get these bolts? What length bolt did you end up buying? Thanks for any help!!
wlee112
Jul 12, 2007 08:13 AM
MISFITofMAGIC
May 21, 2006 11:14 AM
AllSpedup04
Sep 27, 2005 12:24 PM
SD_EM1
Jun 10, 2004 11:28 PM
Train
May 6, 2004 09:49 PM
