T3/T4 Downpipe, ERZ Intercooler, Budget T3/T4 Turbo, turbo Oil feed line
here you go guys
T3/T4 downpipe 5 bolt flange Full stainless steel gasket included
120 shipped
ERZ intercooler 185.00 shipped
core length : 20 1/2"
core height : 9"
core thickness : 2 3/4"
inlet/outlet size : 2 3/4"
end to end length: 28"
Budget T3/T4 Turbo , 265.00 shipped
3" INLET DIAMETER
2"OUTLET
WET FLOAT BEARING
1/8 NPT OIL INLET
.50 A/R COMPRESSOR
.63 A/R TURBINE
.57 TRIM
Turbo Oil feed line kit 55.00 shipped
-1/8" Adapter NPT male fitting that goes to the block and one- 4AN male fitting buitl on flange.(made out of Grade 7075 Alum).
-36" long stainless steel braided line with 3/8 diameter
-comes with gasket, screws/washer
-will work with t3 t4 to4e t60 t61 t60-1 turbo
Budget Turbo timer, 45 dollars shipped
paypal email is sales@eracingzone.com
Modified by ERZperformance.com at 11:17 AM 6/12/2007
120 shipped
core height : 9"
3" INLET DIAMETER
2"OUTLET
WET FLOAT BEARING
1/8 NPT OIL INLET
.50 A/R COMPRESSOR
.63 A/R TURBINE
.57 TRIM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano »</TD></TR><TR><TD CLASS="quote">for what manifold is the downpipe for??
Adriano</TD></TR></TABLE>
x2
x2
this is type of manifold it will fit, these manifold are all over ebay and has been selling for the pass three year now, will not fit Blox short manifolds
"budget turbo" = ssac ?
looks like it might be, since you're posting a ssac mani and dp
What size is that DP?
I'm guessing it's flanged for a standard eBay turbo like the one you have for sale?
Regarding the turbo, are you having any luck with them holding up for a while, and if they don't, are you able to stand behind them at all?
Thanks!
Thad
Thanks!
Thad
b16ajdmrex
May 22, 2012 06:44 PM
DavidR
Jun 2, 2005 01:00 PM
