Civic SI tranny swap into 91 Dx/Std need Civic SI axles?
Old May 31, 2007 | 07:21 PM
ESP.net's Avatar
Default Civic SI tranny swap into 91 Dx/Std need Civic SI axles?
My father has a 91 STD 4spd Hatchback. I have a 90 Civic SI tranny can I re use the STD/Dx axles? splines the same for tranny and hub or will I need to do some switcharo to SI axles and hubs.
Also Civic SI trans gearing close to something like a ZC sohc 88-91 just wondering if it's worth the $300 for the ZC sohc non lsd tranny.
Last question STD/DX clutch N flywheel work with the Civic SI trans?
Modified by ESP.net at 8:32 PM 5/31/2007
Old May 31, 2007 | 07:32 PM
dr_latino999's Avatar
Default Re: Civic SI tranny swap into 91 Dx/Std need Civic SI axles? (ESP.net)
You can retain stock gearing.
Depends if the ZC SOHC transmission has the 4.4x final drive (or 4.3x, I can't remember).
Yes the clutch is compatible, both 90 and 91 were 20 spline setups.
Old May 31, 2007 | 07:35 PM
ESP.net's Avatar
Default Re: Civic SI tranny swap into 91 Dx/Std need Civic SI axles? (dr_latino999)
koo so my STD axles will work then...
Old May 31, 2007 | 07:39 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP.net &raquo;</TD></TR><TR><TD CLASS="quote">koo so my STD axles will work then...</TD></TR></TABLE>
Yes. You want the axles to match the hubs, not the tranny.
So long as they are in the same year range, yes.
crxrider07
Sep 9, 2008 12:00 PM
LurkerS8
17
Jun 25, 2005 07:46 AM
TougeCoupe
Sep 13, 2004 02:49 PM
Red_Si
11
Dec 21, 2003 09:54 PM
zcivicz
30
Apr 15, 2002 02:29 PM
