Coolant leak only when fan is on?
Old May 31, 2007 | 07:09 PM
jpopvriens's Avatar
Default Coolant leak only when fan is on?
I have a problem with a coolant leak on my 1996 Accord, but it only seems to happen when I turn the cars off and the fan kicks on. If the fan does not come on after I turn the car off it doesn't leak. Does anyone have any ideas where it could be coming from?
Old Jun 3, 2007 | 03:07 PM
hondadude's Avatar
Default Re: Coolant leak only when fan is on? (jpopvriens)
cracks in the radiator where the fan mounts up?
Coolant is a liquid and is affected by gravity, so it should be a very simple matter to find the leak.
follow the drops up until it isn't wet anymore.
Old Jun 3, 2007 | 04:31 PM
kleen98accord's Avatar
Default Re: Coolant leak only when fan is on? (hondadude)
buy the crushed aluminum radiator fix. you just pour it into your radiator and let your car run for 15 mins and it wont leak no more. works great.
drshottest718
24
Jun 25, 2016 07:09 AM
moosepoop21
May 2, 2006 06:17 PM
spock_rocker
Jun 6, 2005 03:32 PM
tonezilla
Mar 22, 2004 07:35 PM
