bad head gasket ?
Old May 31, 2007 | 05:02 PM
rdeezy78's Avatar
Default bad head gasket ?
Could a bad hg make the car hard to start. It has to turn over a couple times b4 starting? Could that be because air is in the system? Hg is in bad shape. Swapping in a new motor very soon. So I don't really drive the car. Just worried about the car not starting like it's supposed to. Oh and fyi the car does sit for like a week or so in between rides. For tech puroposes that info was supplied. Thanks for any input and helpfu suggestions if any.
Old May 31, 2007 | 05:50 PM
NJIN BUILDR's Avatar
Default Re: bad head gasket ? (rdeezy78)
It's probably fouling out the plugs.Throw another cheap set of plugs in and see if that helps for a while.
Old May 31, 2007 | 05:57 PM
rdeezy78's Avatar
Default Re: bad head gasket ? (NJIN BUILDR)
I actually have a spare set laying around. I' will try that. Thanks
Old Jun 1, 2007 | 12:36 PM
Lewdin' Incognito's Avatar
Any car will take more time to start if you only run it once a week. Just make sure you give the fuel pump some time to prime the system by holding the key in the "ON" position before you turn it to "START". Also remember that all of your oil is in the bottom of the pan. It still gets pretty cool on PA nights, and generally cold engines with no oil or fuel don't tend to like to run right out of the gates. Probably nothing too serious IMO.
Old Jun 1, 2007 | 06:22 PM
rdeezy78's Avatar
Default Re: bad head gasket ? (Lewdin' Incognito)
I hear ya. Thanks
ivey_usmc
Aug 20, 2011 09:47 AM
h22silvia
Jul 28, 2009 09:53 PM
dmj
May 12, 2008 12:50 PM
wu tang
Sep 15, 2002 08:08 AM
