Pulling vaccum from intake tube?
Old May 31, 2007 | 01:56 PM
silentdaredevil2's Avatar
Default Pulling vaccum from intake tube?
i was curious to know if i could drill and tap a hole for a vaccum source for my wastegate in the intake tube its self. I think it would work but i need a little advice here.
Old May 31, 2007 | 02:06 PM
Flashmn's Avatar
Default Re: Pulling vaccum from intake tube? (silentdaredevil2)
Yes, but a wastegate doesnt work with vacuum, it works with pressure.
Old May 31, 2007 | 04:04 PM
but would it still work using the intake tube?
Old May 31, 2007 | 04:51 PM
dfoxengr's Avatar
Default Re: (silentdaredevil2)
theres no vacuum in the intake before the throttle body.
also vacuum is pressure.
Old May 31, 2007 | 04:55 PM
02 accord's Avatar
Default Re: (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">also vacuum is pressure.</TD></TR></TABLE>
Vacuum is negative pressure.
Old May 31, 2007 | 04:57 PM
dfoxengr's Avatar
Default Re: (02 accord)
ok
Old May 31, 2007 | 05:18 PM
BigPlansNoMoney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">
Vacuum is negative pressure.</TD></TR></TABLE>
Vacuum is pressure below 14.7psi
Old May 31, 2007 | 05:21 PM
02 accord's Avatar
Default Re: (Justin_Bradley)
Yes, but everything is relative to the 14.7 psi, so that makes vacuum negative pressure.
Old Jun 1, 2007 | 10:14 AM
haha yes im aware of the difference between vaccum and postive pressure. BUT can i use the intake tube for the wastegate?
Old Jun 1, 2007 | 10:48 AM
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdaredevil2 &raquo;</TD></TR><TR><TD CLASS="quote">haha yes im aware of the difference between vaccum and postive pressure. BUT can i use the intake tube for the wastegate?</TD></TR></TABLE>
i don't see why not, alot of turbo's have nipples on them for just that.
Old Jun 1, 2007 | 01:07 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdaredevil2 &raquo;</TD></TR><TR><TD CLASS="quote">haha yes im aware of the difference between vaccum and postive pressure. BUT can i use the intake tube for the wastegate?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">theres no vacuum in the intake before the throttle body.</TD></TR></TABLE>
Old Jun 1, 2007 | 04:11 PM
ndogg's Avatar
what is your point? wastegates don't run off vaccum, they run off boost.
YES YOU CAN USE A SOURCE OFF YOUR CHARGEPIPE.
Old Jun 1, 2007 | 06:27 PM
dfoxengr's Avatar
Default Re: (ndogg)
well then i feel dumb. oh well.
as long as its after the turbo then its fine.
Old Jun 1, 2007 | 06:57 PM
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">as long as its after the turbo then its fine.</TD></TR></TABLE>
Old Jun 2, 2007 | 01:04 PM
good to know. thanks
kevinkirk
Honda CR-V & Element
Jun 28, 2014 05:56 AM
418whpturboD
Feb 27, 2008 07:26 PM
95accordh22a
Feb 16, 2005 01:44 PM
B18EG6
Welding / Fabrication
Dec 15, 2004 08:42 AM
TOFU.man
May 1, 2004 07:04 AM
