car won't start
Old May 31, 2007 | 01:11 PM
ge_itr's Avatar
Default car won't start
i have a 90 civic lx AT that won't start most of the time especially when the temp is hot. sometimes it taks a few cranks. when i check for sparks, sometime it'll have spark and sometimes it doesn't, but it still doesn't start. after you let it cool (about 30mins), it would start again, having sparks. usually i just wait for a few seconds then it would restart again, but now it's getting worst. if you drive it for a long time (1-2 hours), it will sound like it's going to stall when you stop, and it did twice (i have to rev a little). has no cel. i got new dist cap, wires and plugs before it started getting worst. 50 amp ign fuse is black but still connects. i might buy a ign coil but not sure if it's the problem. need some advise. thanks.
Old May 31, 2007 | 02:07 PM
mahatma's Avatar
Default Re: car won't start (ge_itr)
search "main relay"
Old May 31, 2007 | 06:21 PM
hondacivic0909's Avatar
its your main relay doin that to you i work at a honda dealership and that is really common so just replace that and you will be fine
Old Jun 1, 2007 | 08:46 AM
ge_itr's Avatar
where is the main relay located, and what does it look like?
Old Jun 1, 2007 | 09:00 AM
ge_itr's Avatar
could it be the main relay because sometimes i don't have spark also. i can also smell the gas if i crank the engine a lot.
nismogrendel
Apr 24, 2010 01:43 AM
ge_itr
Jun 1, 2007 03:35 PM
TizmPizm
Aug 5, 2006 05:14 PM
tboss
Sep 26, 2003 06:30 AM
