Suspension & Brakes Theory, alignment, spring rates....
new illuminas dont come with bump stops?
Old May 31, 2007 | 12:17 PM
NTX
Guest
Posts: n/a
Default new illuminas dont come with bump stops?
are they supposed to include bump stops? do i just re-use the ones i have off my agx's?
what if you dont run dust covers? i lost mine from the last install
Old May 31, 2007 | 12:30 PM
Tyson's Avatar
Default Re: new illuminas dont come with bump stops? (creamsoda)
every set for my crx has come with new ones. cant speak for any other model.
youre fine without dust covers.
Old Jun 2, 2007 | 02:26 PM
inspyral's Avatar
If I remember correctly, the Civic/Integra applications come with new bumpstops for the rears, and you cut your OEM bumpstops and reuse them for the front.
Old Jun 2, 2007 | 02:29 PM
NTX
Guest
Posts: n/a
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">If I remember correctly, the Civic/Integra applications come with new bumpstops for the rears, and you cut your OEM bumpstops and reuse them for the front.</TD></TR></TABLE>
yeah im just going to re-use my old ones
Old Jun 2, 2007 | 06:24 PM
PianoMan's Avatar
Default Re: (NTX)
You cut the front bumpstops, typically, if you're lowered on aftermarket springs. If you're leaving the springs the same, and replacing your AGX, just reuse the bumpstops.
For such a nice set of shocks, I'd look around for some used dustcovers. The clearances between the shock piston rod and seal are pretty durn small, but remember all that crap that gets thrown around the wheel well. A small investment in covers and your premium shocks will thank you in the long run.
PM
corkss
Mar 9, 2009 11:03 PM
amej8
Suspension & Brakes
13
Sep 15, 2008 09:45 PM
ecksman
Jan 4, 2007 05:35 PM
Civicse
Suspension & Brakes
Aug 19, 2005 03:07 PM
vultron
Sep 3, 2003 04:27 AM
