Wheel bearing making noises, have a question - k4 gsxr600
Hey my wheel bearing on the front wheel will probably need to be changed cuz its squeaking and making grinding noises (i whacked a front wheel on a curb couple weeks back) The wheel took it like a champ and didnt bend but the bearing started squeeking 3 weeks later. ANyway, im trying to take it to the shop. Wheel Bearings itself cost like 16 dollars. What should the labor approximately run me? It a shop that charges 66/hour.. i just dont want to overpay..
there very easy to do if you can figure out how to pull a bearing or got someone with a bearing puller.
about an hours work is all it is if the wheel is already off.
Hey Mschu, you remember that that day you helped me out when i was freaking out? Bend wheel, bend forks... man i was paranoid. Well apparently i didnt get away with just a lesson
Gotta go order front bearings now...
