EF Sway bar noise.
So I linked the sway bar how it's suppose to (I did not pre-load the links) and it handles good, the only thing is... it's making a gentle popping sound on my passenger rear tire... is this normal or are the links still too tight? I have the sway bushings tight on the mounting brackets, I will loosen them up.. as it's causing my sway to rattle with my muffler.
HELP!
Modified by jdm4drSi at 3:19 AM 6/1/2007
HELP!
Dang, just read my post... I installed the end links with NO preload. I repeat, NOO preload. I screwed up, but to clear things up... I installed them with the car completely on the ground, leveled on the floor.
Yes, greased the bushings, and am going to loosen the bushing mounts just a tad bit as they are too tight. Let's see if that'll help. I think the popping is not the wheel, but the bar rubbing against my muffler. eh?
LatinEM2
Honda Civic (2001 - 2005)
Oct 14, 2008 09:38 AM
