MPFI-swap ecu contact pins...EBAY?
Old May 31, 2007 | 08:13 AM
gwiffer's Avatar
Default MPFI-swap ecu contact pins...EBAY?
http://cgi.ebay.com/AVIONICS-C...sting
http://cgi.ebay.com/500-New-Ra...wItem
http://cgi.ebay.com/130-New-De...wItem
can these be used? (for adding wires to C1 and C2)
I do not have access to a salvage yard to get these.
Modified by gwiffer at 11:28 AM 5/31/2007
Old May 31, 2007 | 09:00 AM
Super Chicken's Avatar
Default Re: MPFI-swap ecu contact pins...EBAY? (gwiffer)
unless you somehow cut out and destroyed the old pins you should have enough from the original setup. I didn't see any pins that would work anyway. If you need some extras I have some laying around as I have 2 cut up harnesses left over.
C1 and C2 get moved from somewhere else.
Old May 31, 2007 | 11:37 AM
gwiffer's Avatar
Default Re: MPFI-swap ecu contact pins...EBAY? (Super Chicken)
Since I removed my purge cutoff solenoid, dashpot, and ac; I think I can just use those pins instead (A6,B2, or B8). I'll keep the AC clutch pin so I can add vtec later (if i ever do).
FaceTuned
Sep 30, 2014 01:06 PM
ckrieg
Oct 29, 2006 01:47 PM
Slava.
Oct 17, 2006 12:57 PM
CivicHB89
Jan 4, 2005 10:19 PM
eternal21
Nov 19, 2001 04:02 PM
