Tire size?
Old May 31, 2007 | 04:12 AM
MurdersV8s's Avatar
Default Tire size?
I have a set of 205/50/15's on my itr's which are perfect. My question is should I use the same size on my new 15x7 slips? Or should I go bigger to accommodate for the wider rim?
Old May 31, 2007 | 04:15 AM
old man neri's Avatar
Default Re: Tire size? (MurdersV8s)
Tire size is mostly a function of the car you are using. First you select an appropriate size for your car then you ensure that that size is approved for the rims that you have. 205-50s should be good for 7inch rims but you can make sure by looking up the spec sheet for that tire on a place like tirerack.com
Old May 31, 2007 | 05:18 AM
MurdersV8s's Avatar
Default Re: Tire size? (old man neri)
Thanks man. I will check out tirerack.
Old May 31, 2007 | 11:59 AM
MurdersV8s's Avatar
Tirerack doesn't help when it comes to sizing by rim. I called my local tire shop and they said to use 215/50/15 which is really wide if you ask me. Also the cheapest tire they have in that size are $125 a pop which is ridiculous for a 15 inch. What width should I use?
Old May 31, 2007 | 01:28 PM
camusmuse's Avatar
Some tire manufacturers have the acceptable width variance numbers on their site, might have to do a little hunting though. 205, 215 will both work on your 7" rim. Are you lowered? I used to run a 225/50-16 on my 91 accord at stock height with motegi mr8(7.5" wide if I remember correctly), and loved it....it was a little "meaty", but that was the look I was going for(plus its harder to bend rims with the added side wall). I could of lowered it an inch or two without any rubbing either. How wide are your current rims?
Old May 31, 2007 | 02:30 PM
MurdersV8s's Avatar
Default Re: Tire size? (camusmuse)
I am running Tein s techs with 5 lug itr's and 15x7 slips.
Old May 31, 2007 | 06:06 PM
DaveSi677's Avatar
A 205-50-15 will be fine for 15x7 wheel.
Old Jun 1, 2007 | 03:17 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Tire size? (DaveSi677)
Dave is right. Most 205/50-15 tires are approved for mounting on wheels that are 5.5-7.5 inches wide, so they are fine for your 15x7 wheels.
The reason your tire shop told you 215/50-15 is that that size has the same outer diameter as your stock 195/55-15 tires. However, your tire shop did not take into account that (a) 215/50-15 tires on an Integra will rub, and (b) the only tires available in 215/50-15 are crap.
205/50-15
Old Jun 1, 2007 | 06:23 PM
MurdersV8s's Avatar
Default Re: Tire size? (nsxtasy)
Thank you greatly appreciated.
Max713
Jun 6, 2008 06:30 AM
Civicse
Jul 30, 2007 01:49 PM
mugenracer
Feb 24, 2007 10:57 AM
still
Apr 7, 2006 02:35 PM
1SLOWlsTEG
May 20, 2005 01:11 PM
