Vinyl door panels
Old Jun 3, 2002 | 12:22 PM
civicmark's Avatar
Default Vinyl door panels
hey, i'm going to try to wrap my door panels in vinyl on my 92 dx, and was wondering if anyone has ever done it themself, or has any advice.
What glue did u use?
How did u mold the vinyl around the curves and bumps?
How much time did u spend doing it?
thanks
Old Jun 3, 2002 | 02:23 PM
Jaminak's Avatar
Default Re: Vinyl door panels (civicmark)
I did it on my 99 HX. The idea is the same. Once I took off the door panel I used a dremel tool to drill out the plastic rivit things. I got some small bolts from Home Depot and used them to screw the arm rest part back in. I used 3M spray glue to hold the vinyl on. It held well. Here are some pics:
Hope that helps.
-Jamin
Old Jun 3, 2002 | 02:28 PM
Jaminak's Avatar
Default Re: Vinyl door panels (advancexgsr)
Thanks! I wish I still had them for my 96 DX. I guess I'll just have to make more.
Old Jun 3, 2002 | 03:42 PM
JV's Avatar
JV
Who?
Default Re: Vinyl door panels (Jaminak)
Where did you get the vinyl from?????
Old Jun 3, 2002 | 06:22 PM
civicmark's Avatar
how is that 3m glue holding up? i'm just worried of using a glue that will somehwat melt when it gets hot and lose hold of the vinly, but it looks great, do you have any advice on doing them? tricks or tips?
[Modified by civicmark, 3:34 AM 6/4/2002]
Old Jun 4, 2002 | 01:05 PM
Jaminak's Avatar
Default Re: Vinyl door panels (JV)
JoAnns. Any fabric store will have it. Get the thicker kind. Canvas backed, not fleece backed.
Old Jun 4, 2002 | 01:09 PM
Jaminak's Avatar
[QUOTE]how is that 3m glue holding up? i'm just worried of using a glue that will somehwat melt when it gets hot and lose hold of the vinly, but it looks great, do you have any advice on doing them? tricks or tips?QUOTE]
3M spray glue is fine. Basically the glue is there to hold it on while you tighten it down with the screws from the back. It also helps to keep the contour. I never had any problems with it all last summer. It's easies to put on when the vinyl is palpable - use a hair dryer to get it nice and mouldable. Then it will go over any bends and curves that you have. Don't get it too hot tho, or when you pull it tight it will strech too thin.
-Jamin
Old Jun 4, 2002 | 03:28 PM
Mr. Thunderlips's Avatar
Now if I could just figure out how to take off the window rolling down lever thingy.
Old Jun 4, 2002 | 03:41 PM
tunedcivic's Avatar
Default Re: Vinyl door panels (ThunderLips)
there is, on my 4g, a ring spring thing around the base...u get a screw driver and push the spring off and it comes out
Old Jun 4, 2002 | 06:25 PM
slowEJ6's Avatar
Default Re: Vinyl door panels (tunedcivic)
i wrapped the tops of my doors and the armrests in vinyl as well....came out alright, used too thin of a vinyl but it will suffice for now until i have the time to redo it again.
Old Jun 6, 2002 | 02:26 PM
civicmark's Avatar
Default Re: Vinyl door panels (hybrid3do0rcx)
well, i wrapped part of them last night and it was much harder than i thought but came out pretty good. I wrote a text on how i did it, and i'll get pictures up tonight
thanks for all the help
Old Jun 11, 2002 | 07:54 PM
prjctCIVIC's Avatar
did you pull off the old fabric and wrap new vinyl around it?? or did u wrap the vinyl over the old fabric?? what sizes screws did u use to hold the back the piece in place??? do u need washers??? thanks
Old Jun 12, 2002 | 02:06 PM
Animal-Chin's Avatar
Default Re: Vinyl door panels (prjctCIVIC)
I wrapped mine awhile back... I took off the existing fabric, and used it as a template for my new fabric. After I did mine, my friend asked me why did I take off the existing fabric.... he said the new material would stick better to the existing fabric versus the actual panel itself. I can't remember what size screws but be careful when youre screwing them in, I accidentally screwed too far on one and it starts to show on the other side. I didnt use washers when i did mine.
[Modified by formulaEG6, 3:08 PM 6/12/2002]
Old Jun 12, 2002 | 02:12 PM
Jaminak's Avatar
Default Re: Vinyl door panels (formulaEG6)
I left the fabric on. I don't know about it sticking better, but having it there makes it softer to put your arm on. Use 1/4" x 3/8" machine screw phillips ($0.20 for 2 @ home depot). Do use washers. You can use more than one to avoid screwing through the back end. I went through once also. Luckily it was under the arm rest so it didn't show up that much. Be carefull when you put the screws in though - as you get deeper slow down and be carefull.
-Jamin
Old Jun 13, 2002 | 10:55 PM
prjctCIVIC's Avatar
in the pic with the armrest, did u wrap the lid part also???
Old Jun 14, 2002 | 07:05 AM
Jaminak's Avatar
The center arm rest? Yes, that also.
LeeFred
Mar 22, 2018 09:03 AM
myhondasrusty
Jan 26, 2010 07:48 PM
eL
Honda Civic (2006 - 2015)
Dec 19, 2006 05:02 AM
crxsi8
Apr 8, 2005 04:04 PM
