TW: 93 Civic Hb Cx Ventura Ca. Clean TITLE
Alright well I was driving the car today and I guess there was a crack in the oil pan and all the oil leaked out and seized the motor. So I need to sell this car NOW! I have over 9K plus into this car. I havent taken it apart but im sure the bearings on the crank seized up. Im willing to trade the car for something else or part the car out. First 4500 takes it i have this into the motor alone.
93 Civic hatchback CX Clean title
Exterior:
Has a silver paint job that was done about a year ago. ( A few months after paint job a car scraped the side of the car Wasnt to bad slight damage but should be replaced. Ill get pics Needs a new front bumper and passenger fender then painted . About 400 dollars for everything.)
Full Viper alarm( Power door locks, Motion Sensor, Hood pin sensor, Back up battery on alarm, Ignition kill switch.
Carbon Fiber hood
Carbon Fiber Duck bill
Jdm Corners
Spoon style abs front lip
Rota GT3's Red with silver lip. Tires have about 90% tread on them
Interior: Bride front seats. ( They faded to brown but I have professional dye kit for it to put them back to black)
Civic si cluster
Alpine dvd player
Pioneer front speakers
S2000 shift ****
Engine: B20/ Vtec 84.5mm w/Gsr head Motor only has about 1000 Miles on it Crank was fully balanced and motor was cleaned and Honed
Car is running good Needs New valves tho. Its currently running stock injectors and stock cams but has the following Havent had any time to install some of the parts and tune it
Sparks Racing 12:1 compression pistons
Block Gaurd
GSR Stock Rods
ACL bearings
RM valve springs and retainers
Skunk 2 ECU
Skunk2 Pro 2 Cams (Not installed Yet)
STR Cam gears( Not installed yet)
440 injectors( Not Installed yet)
B&M AFPR w/ Gauge
Blox Intake
Gsr Tranny
ACT 4puck sprung clutch
Matix Short ram intake
Suspenion: Tein Suspenion
Has slotted rotors but there cracked I have new brake and brake pads for them just not yet installed.
Has extended studs and lugs nuts but passenger side had two break off and has two regular studs.
I will try to get more pics of the car and the damage to the car also pics of the engine bay and seats. These pics didnt have seats in it at time.
Modified by Project92Hatch at 5:58 PM 5/31/2007
Modified by Project92Hatch at 12:04 AM 6/8/2007
Exterior:
Carbon Fiber hood
Jdm Corners
Civic si cluster
Alpine dvd player
S2000 shift ****
Block Gaurd
GSR Stock Rods
ACL bearings
Skunk 2 ECU
B&M AFPR w/ Gauge
Blox Intake
Gsr Tranny
Actually ive meet you before lol. I used to have a gsr motor in it and blades on it. I meet you at the races along time ago with raul lopez. I raced like a b16 hatch.
No when i was putting in the valve springs and retainers i checked to see if the seal on the vavles were still good. And they werent to good. So i took them out to replace them but then some things came up and I had to just put the same vavles back in and they didnt go back in the same order. So the seals got even worse. Im probably gonna take care of this before the car is sold tho. Just needs new vavles. And a 3-angle vavle job wouldnt hurt
Turbo93Eg
Sep 9, 2010 10:22 AM
dookstainsteve
Texas -OK -LA (Sales)
Nov 3, 2008 06:49 AM
Project92Hatch
Jul 3, 2007 11:08 AM
Project92Hatch
Jun 28, 2007 11:18 AM
