Locked lugs, can't find the tool for it.
Old May 30, 2007 | 11:21 AM
Booz's Avatar
Default Locked lugs, can't find the tool for it.
I bought this car a few months ago w/ brand new tires and didn't think much about having to take them off at the time. Each tire has 4 locking lugs on it but no hardware store seems to know what tool I use to get them off. I called the guy I bought it from and he said he used some type of flat edge but I'd prefer to have an actual tool. Here are the pics as best I could get them.
The wheels are ICW racing rims 15". The lugs are smooth on the outside w/ no edges, and a shiny magenta color. And there are points on the inside to grip them but seem to be worn away from using something other than the prefered tools.
Thanks
Old May 30, 2007 | 12:35 PM
-RedneckDave-'s Avatar
Working
Default Re: Locked lugs, can't find the tool for it. (Booz)
Go to a tire shop near where you live and they will have it, or you can go to sears and get a huge allan wrench and take them off that way.
Old May 30, 2007 | 12:40 PM
gabebauman's Avatar
Default Re: Locked lugs, can't find the tool for it. (-RedneckDave-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -RedneckDave- &raquo;</TD></TR><TR><TD CLASS="quote">Go to Sears and get a huge allan wrench and take them off that way.</TD></TR></TABLE>
Yup...I had lugnuts similar to that on my first set of wheels. When I had a problem with some of them coming off...I went to Sears and purchased a 12mm Allen Wrench. Slide your jack handle over the wrench and they should come loose if the inside is not to rounded off.
Old May 30, 2007 | 06:40 PM
Booz's Avatar
Default Re: Locked lugs, can't find the tool for it. (gabebauman)
Thanks a lot guys.
Old May 30, 2007 | 08:17 PM
2.0L EK's Avatar
use a 3/8" ratchet with a short extension should fit perfect
Old May 30, 2007 | 08:24 PM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Booz &raquo;</TD></TR><TR><TD CLASS="quote">Thanks a lot guys.</TD></TR></TABLE>
So did you get them off?
Old May 30, 2007 | 09:50 PM
hayabusa160's Avatar
its most likely a 12 or 14mm hex
soak them bad boys in wd40
Dontoh
Dec 27, 2009 08:58 PM
92egSnatch
31
Mar 31, 2008 03:58 PM
Tuner Eddy
Apr 14, 2007 07:54 AM
civicgsr93
11
Oct 27, 2003 09:28 AM
LSpeed
Jan 30, 2002 05:54 PM
