ECU light STUCK on.
Could be an ecu fuse or ignition fuse...
Solid CEL indicates that your ecu isnt being powered up sorta speak... which means theres a break in the circuit... so check fuses before you go replacing ecu's
also, make sure all your wiring is correct before changing anything, so it doesnt fry any of the new parts.
