Help/Advice on a Quick Release Hub.
From: fountain inn, sc. where they still rock banjos on porches, usa
i have this very nice crx steering wheel. but the problem is i live in a..... well lets just say the crime rate is high and the area is filled w/ricers. i want to put in a quick release hub. i'm also throw in some other things to help prevent my car being jacked. but let's take a look at the wheel.
if you notice it has only 3 allen key srews that secures the steering wheel to the hub. the other 3 small ones are to secure the horn adapter to the wheel which then lets honda horn piece clip on.
the screw formation is called F1 screw position(i was told, that's how it was back in the day.). now all the hubs are 6 screw pattern. the reason is i've been looking NRG quick release hub. but i really don't want to spend a **** load of money then it doesn't work w/my wheels. and buying a cheap knock off is out of the question. so any ideas.
the ball bearing style from NRG is not a good one to get in my opinon. i have one currently and some of the bearings have fallen out. also, that is the most common type (theives can carry that setup with them). you can look into an FET style quick release or the Techniq auto (150.00) one. but just dont rely on that as your only theft deterrent, make sure you have layers. i will eventually get the techniq auto one.
93egSLEEPER
Dec 8, 2007 12:52 PM
xaznxdrgnxboix
Sep 9, 2007 08:58 PM
