Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
04-05 Ebay Fogs HELP.....Please (Pics)
Old May 30, 2007 | 11:07 AM
italy273's Avatar
Default 04-05 Ebay Fogs HELP.....Please (Pics)
Hi, I just purchased the 04-05 civic fogs. I need some help figuring out the harness. On the Honda instructions it says things about 16, 10, and 4 pin connectors and the Ebay fogs don't have any. All I have is 1 single pin plug left.
--Is #1 the constant power source and do I plug it into the fuse box under the steering wheel?
--Do I plug #1 into spot #2 in the fuse box or should I run it somewhere else?
THANKS
Modified by italy273 at 6:02 PM 5/30/2007
Modified by italy273 at 6:05 PM 5/30/2007
Old May 30, 2007 | 12:51 PM
<StevieG>'s Avatar
I plugged mine under the steering wheel, but my fogs don't turn off when i turn on my high beams, which makes them illegal.....but i enjoy it like that. i can see better at night.....
Old May 30, 2007 | 01:47 PM
italy273's Avatar
Default Re: (03civicdopejmd)
so you did plug it in the #2 spot under the steering wheel fuse box which is constant power.
Old May 30, 2007 | 02:32 PM
Todd00's Avatar
I said I don't want a title!
Default Re: (italy273)
It's not that difficult...
Just get one of those circuit testers for like $3.99 and figure out what spot has power when. You want a location that offers power when the car is on. You may be able to find a spot that offers power when the parking lights and headlights are only on.
You don't want to plug into a spop that offers constant power even with the ignition off.
Old May 30, 2007 | 04:37 PM
tibbs420's Avatar
sweet i just bought those too and i am thankful or any info
Old May 30, 2007 | 05:05 PM
italy273's Avatar
Default Update
Well I tested the fogs and hooked everything up and grounded everything and the fogs work.
I pluged the wire into the contant power fuse and now the fog switch is always lit and I can turn on the fogs even though the car is off.
Where would be a good safe place to get power to turn on the fogs only when the car is on or the ACC position.
Old May 30, 2007 | 08:07 PM
Todd00's Avatar
Default Re: Update (italy273)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by italy273 &raquo;</TD></TR><TR><TD CLASS="quote">Well I tested the fogs and hooked everything up and grounded everything and the fogs work.
Where would be a good safe place to get power to turn on the fogs only when the car is on or the ACC position.</TD></TR></TABLE>
Already answered. You're going to have to do some testing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
You don't want to plug into a spot that offers constant power even with the ignition off.
Old May 31, 2007 | 04:43 AM
italy273's Avatar
Default Re: Update (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Already answered. You're going to have to do some testing. </TD></TR></TABLE>
I did some testing with my circuit tester but I just wanted to know if anybody knew of a good safe place I could get power to the fogs and I don't want to run it straight to the battery.
I hate doing electrical work in my car so I just want to make sure I am doing ti right the first time and that it is going to be safe and not catch on fire. BTW I have a inline fuse where the fogs get power.
Old Jun 1, 2007 | 06:40 AM
italy273's Avatar
BUMP....Anybody know where the parking light wire is around the the steering wheel area.
Thanks
Old Jun 3, 2007 | 10:29 AM
italy273's Avatar
Bump...I found the parking light wire on the fuse box.
Is it safe to tap the power wire from the fogs to the parking light wire???
Old Jun 3, 2007 | 10:56 AM
b0yg0tskills's Avatar
hello i ordered one from ebay too but the switch was defected and some of the plugs didnt even fit into the other plugs...me and my cousin found a way to just by pass how the set up is suppose to be which im able to turn on my fogs without the car key even being in the car
Old Jun 3, 2007 | 06:42 PM
SE3Pimp's Avatar
Default Re: 04-05 Ebay Fogs HELP.....Please (italy273)
heres honda's official manual i used myself
http://www.handa-accessories.c...s.pdf
http://www.handa-accessories.com/civic/05fogs.pdf
Old Jun 5, 2007 | 10:53 PM
00falcon's Avatar
i just got mine today and spent all afternoon to install... but lo and behold it doesn't work and my interior is still gutted...
did yours come with a 4 prong female connector that seems to go to the one on the left of #2? it fits but there are only 3 prongs on the fuse and on my harness it only has a connection on the one farthest to the left. i think thats were the problem is cause when even when i have the engine on the fog light switch isn't on... indicating no power right? i'll post pics tomorrow.
Old Jun 6, 2007 | 02:44 PM
italy273's Avatar
Default Re: (00falcon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00falcon &raquo;</TD></TR><TR><TD CLASS="quote">i just got mine today and spent all afternoon to install... but lo and behold it doesn't work and my interior is still gutted...
did yours come with a 4 prong female connector that seems to go to the one on the left of #2? it fits but there are only 3 prongs on the fuse and on my harness it only has a connection on the one farthest to the left. i think thats were the problem is cause when even when i have the engine on the fog light switch isn't on... indicating no power right? i'll post pics tomorrow.</TD></TR></TABLE>
Mine didn't come with the 4 prong female conector like you. I tested the male prongs on the plug next to spot 2 and that is an optional plug and the last prong on the right turn on when the parking lights are on.
I think you don't have any power going to the switch and fogs. you might have to tap it into a power source becasue of the plugs you got.
Old Jun 6, 2007 | 04:28 PM
00falcon's Avatar
so did you get yours to work?
okay here are some pics...
1 is the four prong female with only a prong that actually has a line as indicated by the wire... the male part only has three and is connected to nothing
2 is the one prong and was a pain to connect for some reason
this is the switch and relay.... the switch doesn't light up or anything...
this is the glove box... i donno where that 4 prong connector goes to... it is part of the subharness... it also has a 1 prong connector in the fender that i don't know what is for...
any help would be appreciated... last resort would be to go to the dealers and buy a real harness/switch.
Modified by 00falcon at 5:44 PM 6/6/2007
Old Jun 7, 2007 | 09:15 PM
00falcon's Avatar
bump anyone??
Old Jun 7, 2007 | 09:26 PM
awang's Avatar
i just bought the exact same kit, and the wire that comes through the fender is too short for me to connect to the third and final harness... HELP!!
Old Jun 9, 2007 | 05:31 PM
italy273's Avatar
I wired everything together and everything works!!!
I just had to extend one wire. The wire that goes from the pass side to the center console. I wired my fogs to the parking lights so that way I don't forget to turn them off and drain my battery.
My kit only had a one prong conter that goes to the fuse box that I cut and taped into the parking light that is in spot G9 on the fuse box under the steering wheel.
Old Jun 9, 2007 | 08:19 PM
awang's Avatar
i finally got mine wired as well and it works SO MUCH BETTER THAN I THOUGHT!!! i can turn it on 1) w/the parking/headlights off 2)with the parking lights on 3) with the headlights on 4) with highbeams
i'm estatic!!! woot
Old Jun 10, 2007 | 12:02 PM
homelessEm2's Avatar
hi, i was windering where u bought ur fogs from and did u have any issues hookin them up./gettin them to work. also yellow or clear and do u have final pix?
thanks
leon
Old Jun 10, 2007 | 11:36 PM
awang's Avatar
Default Re: (homelessEm2)
i bought my foglights from a forum member who had purchased them from ebay. the only issue i had with mine was that one wire was too short and i had to extend it. i got clear, and i'll have pics up tomorrow
Old Jun 12, 2007 | 03:18 PM
chinkest_raver's Avatar
This should help you. If the ebay fogs are OEM style then this should work. GL.
http://www.handaaccessories.com/civic/sifogs.pdf
92b16vx
54
Feb 8, 2012 07:52 AM
Frost7177
Apr 3, 2008 05:52 PM
KFBhonda
Jun 17, 2005 10:28 AM
AMF Racing
24
Feb 13, 2005 03:18 PM
