clock blinking, cannot use 6-disc cd changer also - Accord 2004 EX V6
Long story short, I had to reset my battery (I just disconnected its negative terminal for like 20 sec). After that clock is blinking on 6-disc cd changer, it is not displaying any other messages, it doesnt say CODE to put the code in, and none of the buttons work on the cd changer except for A/C buttons. I tried to follow instructions to set the clock but with no luck. you are supposed to click and hold SOUND (CLOCK) button until you hear beep to make the clock blink, when i do that, nothing happens, but hey, clock is already blinking...
please advise. thanks
You can not set the clock until you unlock the radio. If you power on the radio the the screen should say code. You will need to input the correct radio code to continue.
thanks guys for help. took the car to the dealership, got it fixed for 30 bucks, not too bad which includes carwash too
when i had my 94 accord and needed code for it, they (different honda dealership) were asking 75 bucks for it though, at that time i decided to replace it with an aftermarket cd player instead.
nrussell
Apr 11, 2006 12:21 PM
Heat
May 11, 2004 05:13 PM
bhupeshkanwar
Apr 14, 2004 07:45 AM
