Calling ZC Experts
I have a ZC CRX Si and am putting a turbo on it. I *might* have some extra cash flow in the next few weeks and was looking at rebuilding the engine to a lower compression and to make it stronger. Does anyone know what the equivalent US market parts are and who I should get them through and maybe the average cost of doing this rebuild. Ex: does it use 88-89 acura integra rods and pistons? I am looking to rebuild to about 8.5:1 compression.
-Use a Re-bushed B18A/B rod's for a D series piston. A machine shop can do this pretty cheep.
-IMO just get forged Arias piston's in what ever CR you want.
EDIT: You can put in A6 piston's and you will have a 8:1 CR
[Modified by Bryson, 12:45 PM 6/3/2002]
Check out my site...
http://www.homemadeturbo.com/ZC.html
The Endyn Roller wave pistons work very well. (designed for the ZC)
Jeff
Jeff
ZDyne = The only possible way I'm able to pull it off.
I'm running it a bit rich (11.5-12) Air fuel ratio so detonation does not exist.
I also have the ignition set to retard .5 deg per pound of boost
good High flow exhaust = less temperature in the cumbustion process.
Very frequent oil changes with new 5W-30 Mobil 1 syn.
