H23 to H22 ???
i plan to swap my h23 to h22....and since im new to preludes can someone list the things i well need to get andthe stufff i need to convert......anything will help
Here's one thing you'll need... https://honda-tech.com/zerosearch
But in short, you'll need the motor, ecu, and your h23 cat won't bolt up to the H22 B-pipe that comes off the exhaust manifold, so you'll need a little exhaust work done. Everything else is a direct swap. Oh yeah, and there's the dizzy, but you'll find these things out the more you research.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast_honda »</TD></TR><TR><TD CLASS="quote">... your h23 cat won't bolt up to the H22 B-pipe that comes off the exhaust manifold.....</TD></TR></TABLE>
Thats not always the case. Mine bolted up just fine.
