98 civic, what springs do i get?
i have a 98 civic 2dr ex and i wanna lower it. could i just get new springs or do i need shocks as well? and what kinda springs/shocks should i get? i was planning on taking off the hubcaps and drivin it on steelies and how many inches should i drop it?
you could buy springs and or shocks.
run height depends on the type of springs you get. you could also get coilovers which allows you to set the ride hieght. research it online. you'll find plenty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic98civic »</TD></TR><TR><TD CLASS="quote">budget is lower the better but less then a grand
purpose is just to look good
probably 2inches</TD></TR></TABLE>
OTS rate Ground Controls with Koni Yellows.
Let's see if this link works - this should answer many of your questions.
https://honda-tech.com/zerothread/1993025
