CLutch fluid on floor
Old May 29, 2007 | 04:45 PM
m3 boostin's Avatar
Default CLutch fluid on floor
Is is the clutch slave cylinder if there is fluid on the drivers side floor?
Old May 29, 2007 | 05:33 PM
numbnuts22715's Avatar
its the clutch master cylinder.
the slave cylinder is on the front side of the transmission.(between the tranny and the radiator)
Old May 29, 2007 | 05:44 PM
dimwitrj's Avatar
It may be the brake master cylinder too since they both use dot3/4 brake fluid.
Old May 29, 2007 | 08:00 PM
Sam92Teg's Avatar
Default Re: (dimwitrj)
Is the level of fluid in your clutch resevoir lowering? Brake fluid resevoir level lowering?
Old May 29, 2007 | 08:30 PM
TB123's Avatar
Default Re: CLutch fluid on floor (m3 boostin)
I have fluid coming out of the back of my clutch pedal too. It is not all over the floor yet, but I would also like to know what this is and how to fix it.
Old May 29, 2007 | 09:01 PM
Exeed's Avatar
Default Re: CLutch fluid on floor (TB123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TB123 &raquo;</TD></TR><TR><TD CLASS="quote">I have fluid coming out of the back of my clutch pedal too. It is not all over the floor yet, but I would also like to know what this is and how to fix it.</TD></TR></TABLE> That's your clutch master cylinder. A problem like that would need replacement. If you need a how-to on how to replace one, PM me and I'll send you a link.
Old May 29, 2007 | 10:08 PM
.Smitty.'s Avatar
Default Re: CLutch fluid on floor (Exeed)
Yeah for sure the clutch master cylinder, but do double check your reservoirs, both clutch and brake, to make sure.
If it is the cmc, here's your link from team-integra. Man, they have everything. http://www.team-integra.net/se...=1158
Goodluck.
Old May 29, 2007 | 10:59 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: CLutch fluid on floor (.Smitty.)
or you can get the quicklutch system from omnipower, if you're interested, PM me for best pricing
Old May 30, 2007 | 01:20 PM
m3 boostin's Avatar
Default Re: CLutch fluid on floor (n1_98whp fit)
yea, my clutch fluid has been low and i have been puttin more in, thanks
Toonz18
Feb 26, 2018 11:54 PM
Mr. Eric
Nov 18, 2008 09:30 AM
gsr1289
Aug 22, 2006 07:11 PM
94TeGsR
Jan 14, 2003 09:00 AM
John
Jan 16, 2002 12:38 PM
