replacing rad fan motor on a 97 prelude....
does anyone know if i have to take out the whole radiator to change the fan motor. the car is not here rite now so i cant inspect it.
i called for the part and i know there are two different types for two different types of radiators, denso and toyo. my gf car is the toyo. but why hell is the toyo so expensive compared to the denso? is the fan assembly really that different for both denso and toyo radiators?
Modified by cmGSR916 at 1:52 PM 5/29/2007
They will both plug up to your car. The only difference is that the bottom mounting bolts will not match up. noo you do not have to remove the radiator.
okay. im looking at the car now an cant figure how i would take the fan assembly out without taking the radiator. is there one or two bolts on the bottem of the shroud?
