Source for hub bearings? (not the entire hub assembly)
Old May 29, 2007 | 11:56 AM
fsp31's Avatar
Default Source for hub bearings? (not the entire hub assembly)
I'm trying to find a rear hub bearing for a 99' Accord V6, but all I've found so far is the entire assembly. Anybody have a good source?
I haven't tried the dealership, but I assume IF they have it then it will certainly be prohibitively expensive...
Thanks!!
Old May 29, 2007 | 12:44 PM
Patman's Avatar
I bought my hub assemblies at the dealer for 92 each for my car. Not too bad, I'm talking about the rear ones. The change was simple.
92 vs 80 dollars for OEM vs auto parts store price.
Unless you have your own bearing press its pretty much the same in price to replace the whole hub.
Old May 30, 2007 | 03:20 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Source for hub bearings? (fsp31)
correct me if I'm wrong but isn't the rear hub/bearing a one piece assembly anyways? Meaning it can't be serviced separately?
Part #2 - Rear Hub Unit Bearing Assembly - 42200-S87-C52
You can get it at online dealership sites for ~$75 (plus shipping/handling) or you can get it at a local dealership for probably ~$90 (plus tax).
Old May 30, 2007 | 09:43 AM
fsp31's Avatar
Default Re: Source for hub bearings? (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">correct me if I'm wrong but isn't the rear hub/bearing a one piece assembly anyways? Meaning it can't be serviced separately?</TD></TR></TABLE>
This may be inexperience on my part... I've worked exclusively with Civic's for a lot of years and I was thinking the hub assembly for the Accord looked very similar. It looks like the bearing is just pushed in (or out) of the hub assembly with a press. I've done several hubs on Civic's where I simply purchased a new bearing and had it pressed in at a machine shop. Wish I could remember where I got those bearings though! Oh well, not like it was going to save a ton of $$$ anyway...
Old May 30, 2007 | 10:02 AM
SkimN's Avatar
TASAuto.com $50 check Majestic Honda also not sure on prices, but the accord store is probally cheaper
jerzey908
Apr 13, 2015 03:20 PM
papa-g
12
Mar 16, 2010 12:16 PM
PaChiLa Leader
Feb 18, 2009 05:21 PM
Hemix
10
Mar 5, 2007 06:12 PM
SpoolnEG6
Sep 3, 2005 10:30 AM
