trans in hybrid crx w/ tipe-r
Old Jun 3, 2002 | 09:13 AM
dash's Avatar
Default trans in hybrid crx w/ tipe-r
hi there
i am about to do my swap (B18c5 into 91 crxsi) i want to stay withe a cable trans so i want to go with a 90-93 teg trans. will i have to change the fly wheel and starter to the 90-93 one? is there a difernce between the rs and ls trans?
one outher thing the injectors on the B18cd5 are not pek hold ( in short they will not plug into my 91 harnes) right? should i just use b18b injectors , of rewire the harness for the plugs. thanks
Old Jun 3, 2002 | 09:25 AM
memphiss13's Avatar
Default Re: trans in hybrid crx w/ tipe-r (dash)
do not use an LS trans. the gears are not right for the ITR motor. the tranny will make the car feel slower than its supposed to be. what u can do is use a JDM SIR trans. its cable and can also be found with factory LSD. LS trans on an ITR motor for even thinking about that one.
[Modified by rookie2nr, 12:27 PM 6/3/2002]
Old Jun 3, 2002 | 09:39 AM
dash's Avatar
Default Re: trans in hybrid crx w/ tipe-r (rookie2nr)
ok that is i thought the ls trans would be gared to tall, but what if i took out the inards of the ls and swaped them withe the type-r??????
Old Jun 3, 2002 | 10:05 AM
memphiss13's Avatar
i don't know about that one. but really i don't think you want to go through the trouble when u can just get a JDM SiR trans with LSD and be just fine. also, if u are will to take a tranny apart then why aren't u will to convert to hydraulic trans.
Old Jun 3, 2002 | 10:26 AM
dash's Avatar
i have had some bad experances w/ hydro clutches
Old Jun 3, 2002 | 11:02 AM
Speed PHreak's Avatar
JDM S1/J1 damn near identical to the ITR gearing, no LSD however, but cable none the less. 90-91 clutch disk(24mm). I had one, short short gears. Perfect for that ITR engine.
Old Jun 4, 2002 | 10:11 AM
dash's Avatar
Default Re: trans in hybrid crx w/ tipe-r (Speed PHreak)
anyone elese out there with suggestions
Old Jun 4, 2002 | 01:03 PM
SpooN Man's Avatar
an s1 would be just fine. Ys1 with lsd is the best choice.
Old Jun 4, 2002 | 01:43 PM
erniecars's Avatar
Default Re: trans in hybrid crx w/ tipe-r (SpooN Man)
I personally have a JDM s1. This is the way to go. I like it a lot more than a y1 but lsd is nice. Perhaps a custom JDM s1 with lsd would be ideal? You could get the lsd out of a JDM lsd y1 tranny maybe?
9integra3
Transmission & Drivetrain
Jun 7, 2012 07:32 PM
SwapShopR
Dec 18, 2007 09:27 AM
B16acivicsedan91
May 9, 2007 01:17 PM
1.8EG-T
Jul 29, 2001 01:22 PM
