GM Syncromesh Fluid
Old May 29, 2007 | 10:22 AM
grand champ's Avatar
Default GM Syncromesh Fluid
I have heard that some people will mix in some GM sycromesh transmission fluid with their honda MTF and its supposed to help a bit with syncro grinds???
any experiance??
Old May 29, 2007 | 10:46 AM
ilovemycoupe's Avatar
I'm a Jackass
Default Re: GM Syncromesh Fluid (grand champ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grand champ &raquo;</TD></TR><TR><TD CLASS="quote">I have heard that some people will mix in some GM sycromesh transmission fluid with their honda MTF and its supposed to help a bit with syncro grinds???
any experiance??
NO DO NOT DO THIS...IF U WANT TO STOP GRINDS THIS IS NOT THE SOLTION, JUST RUN PENZOIL SYNCROMESH....
but make sure to get your specific #
oem is for lowert mileage trannys....syncro is for higher mileage wearing down trannys.....
over 100k syncro
under oem
then again you can run syncro under 100k....but don twaste your money .....
but if you also constantly beat on your tranny it reccomended running syncromesh, due to the high wear you put on the syncors...
Old May 29, 2007 | 11:45 AM
what about redline synthetic mtf??
Old May 29, 2007 | 05:22 PM
standbackimapro's Avatar
The best Transmission Fluid ive ever used is BG Synchroshift II, stops grinds ( unless u got a majorly fd up trans)
http://www.prostreetonline.com...t.asp
Old May 30, 2007 | 09:41 AM
blinx9900's Avatar
DONT MIX, i just use 100% pennzoil synchromesh in my ctr trans and I LOVE IT!!!!
Old May 31, 2007 | 07:01 AM
Scott_Tucker's Avatar
Default Re: (grand champ)
I'm using Redline MTL in my EP3 and man did it make it shift smoother over stock Honda MTL.
Old May 31, 2007 | 12:02 PM
BGWarren's Avatar
Default Re: (Scott_Tucker)
i used 80w-90 gear oil for my f'd up tranny
but have had good experience w/ syncromesh on a 3rd gear grind trans
Rene1123
Jun 23, 2010 09:59 AM
singher01
Jul 25, 2008 10:19 AM
DB8-teggy
Dec 16, 2006 04:56 PM
accordinglyevil
Aug 5, 2004 11:46 AM
jk
Sep 24, 2002 02:11 PM
