RADIATOR FAN
Old May 29, 2007 | 09:01 AM
v-tecnition's Avatar
Default RADIATOR FAN
ok so my friend drives a p5 accord lx 4 door and sometimes when he turns his car off and takes the keys out the fan still stays on, why does it do this and how can it be fixed because it drains his battery completly, it has remote start too.
Old May 29, 2007 | 09:22 AM
JimBlake's Avatar
Default Re: RADIATOR FAN (v-tecnition)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-tecnition &raquo;</TD></TR><TR><TD CLASS="quote">ok so my friend drives a p5 accord...</TD></TR></TABLE>So is that a '85, '95, or '05??
Depending on year, problem could be 2nd fan switch and/or fan timer module.
Old May 29, 2007 | 01:53 PM
Default Re: RADIATOR FAN (JimBlake)
its 95 sorry
Old May 29, 2007 | 05:52 PM
BLKFLSH's Avatar
Problem: The fan runs continuously (longer than 19-minutes) when the key is removed. The symptom is a dead battery. The fan turns off only when the ignition is turn off then on. 99% chance the fan timer is bad. Usually happens to the 90-93 Accords.
Solution: The reasonable solution is a replacement of the timer control unit. Before a replacement it would be wise to troubleshoot. When the fan does not turn off after 15 minutes swap the cooling fan relays in the engine fuse compartment with another identical relay. If the fan refuses to turn off replace the fan timer unit.
Replacement: Remove the access panel on the driver's kick panel and search for a box way in there the size of two cigarette packs with 8-terminals. The 86-89 Accord fan timer unit is located under the passenger seat. Unbolt the unit and swap it with a new one.
Old May 30, 2007 | 04:10 PM
hondadude's Avatar
Follow the top radiator hose back to the engine, there is a temp sensor there; when the fans are running after shut down unplug that sensor to see if the fans turn off.
If the fans shut off replace that sensor.
Old May 31, 2007 | 08:16 AM
Default Re: RADIATOR FAN (hondadude)
thanx i hope this works
automan12
Jun 7, 2014 04:26 AM
ZillaG
May 5, 2013 12:38 AM
1989 Honda Accord
Jan 3, 2013 06:48 PM
loup05
Oct 22, 2006 05:20 PM
blackdude
May 24, 2004 03:43 PM
