Warmed up Hesitation
Old May 29, 2007 | 08:55 AM
NNV's Avatar
NNV
Default Warmed up Hesitation
Ive searched but nothing came up, anyways, My car runs good for the most part...however when I sit in traffic for a while and the water temp sensor goes to half (max operating temp) the car starts hesitating a little bit when i step on the gas...any idea what could cause this?(92 Si 5Speed H23)
Old Jul 10, 2007 | 05:06 AM
racer69's Avatar
Default Re: Warmed up Hesitation (NNV)
Everyone told me to change the Knock Sensor, but that didn't do the trick. You could try it for about $140 and it may work or maybe not.
Old Jul 10, 2007 | 08:45 AM
h22srb's Avatar
i have the exact same problem , but my temperature meter dosnt go to max , only one bar , it never reach higher then one bar , but when ever i'm in traffic and on a hot day my idle will rise, it once reached the point of idling at 2000 rpms , this happend when i sat in traffic for 35 minutes , does any one know what could be causing it to idle that high. ?
Old Jul 10, 2007 | 10:52 AM
typeS's Avatar
Default Re: Warmed up Hesitation (h22srb)
weird, your temperature should hit the first two bars, anything after that is pretty much bad.
Old Jul 10, 2007 | 08:07 PM
Silver Surfer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NNV &raquo;</TD></TR><TR><TD CLASS="quote">water temp sensor goes to half (max operating temp)</TD></TR></TABLE>
half is two bars
don't know about high idle, but hesitation could be any number of things. does it hesitate at low or high rpms or both? if the ignitor is going bad it will fail more at higher temps.
it's not very cheap to check this or the knock sensor because the parts are rather expensive
Old Jul 10, 2007 | 08:17 PM
Speedra500's Avatar
Default Re: Warmed up Hesitation (Silver Surfer)
if it only happens when the car gets to full operating temperature it makes it sound like a closed loop problem. Like an O2 sensor, have you already checked the basics like plugs, cap and rotor? Does it hesitate like a misfire? or just no power?
ls19integra95
Jan 15, 2008 02:01 PM
mistahmac
10
Aug 29, 2007 05:41 AM
WihaSi
Apr 14, 2007 05:42 PM
OrangeBoost
May 25, 2006 02:46 PM
