05 accord v6 ecu or cams????
new J block is shorter than the previous one so CL type S cams are out. I am not aware of any V6 cams for 03+accords. messing with the ECU is pointless since it will adapt to whatever change you made to it.
run 91+ octane in it for 10HP more
Hondata plans to come out with one next year (2008). As for cams, the only way for you to go is custom but without an ECU, you're just going to mess something up. You can however add a cold air intake and OBX headers on your V6 Accord. I have the same set up with some major headaches due to the OBX fitting issue.
