Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Civic R18 Ecu
Old May 29, 2007 | 04:52 AM
renton's Avatar
Default Civic R18 Ecu
dear Folks,
Any idea where to get the Civic 1.8l with R18a engine ecu diagram?Also the Si ecu diagram?Newbie..pardon me..
Old May 29, 2007 | 09:34 AM
IT GUY's Avatar
Default Re: Civic R18 Ecu (renton)
and why would you need these diagrams?
Old May 29, 2007 | 03:49 PM
renton's Avatar
For piggybacks..doing a camcon on the 2 rides...
Old May 29, 2007 | 11:54 PM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by renton &raquo;</TD></TR><TR><TD CLASS="quote">For piggybacks..doing a camcon on the 2 rides...</TD></TR></TABLE>
what is that?
Old May 29, 2007 | 11:55 PM
20strong's Avatar
Default Re: Civic R18 Ecu (SeanJohn1802)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">
what is that?</TD></TR></TABLE>
X2
Old May 30, 2007 | 06:33 AM
FA5's Avatar
FA5
Default Re: Civic R18 Ecu (20strong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20strong &raquo;</TD></TR><TR><TD CLASS="quote">
X2 </TD></TR></TABLE>
http://www.outperformanceshop....1.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by renton &raquo;</TD></TR><TR><TD CLASS="quote">dear Folks,
Any idea where to get the Civic 1.8l with R18a engine ecu diagram?Also the Si ecu diagram?Newbie..pardon me.. </TD></TR></TABLE>
I should be able to get you the diagrams for both. Gimme a few days.
Old May 30, 2007 | 06:55 AM
IT GUY's Avatar
the cam adjustments may stick, but didn't somone figure out that fuel adjustments made will be "learned" away by the mass air system. Piggybacks may look cool mounted in the interior compartment, but they really aren't that great at tuning...
any reason you're installing camcons on an R18 and a K20?
Old May 30, 2007 | 07:07 AM
renton's Avatar
Default Re: Civic R18 Ecu (IT GUY)
camcon differs in a way that signals are cheated after they leave the ecu. For eg.
ECU---&gt;CAMCON---&gt;final destination. I have done a trial on a Civic Si using Unichip and Camcon. What I did was,
Unichip--&gt;Ignition Timing control and AFR
CAMCON--&gt;Cam lifts and iVTEC Lift control
Heres the dyno result
We did a stage 1 skunk 2 cams as well.
Still looking for an R18 to try out.
Old May 30, 2007 | 07:19 AM
IT GUY's Avatar
what's the deal with the dyno chart cutting off before 7k?
I didn't think peak power came until 7800 (correct me if I'm wrong)
were you just tuning the low cam profile? where is the vtec crossover set (couldn't pick it out in the curve)
where is the rest of the graph? I guess is my big question. it's missing 1200rpm or more
Old May 30, 2007 | 09:47 AM
FA5's Avatar
FA5
Just out of curiosity, how long has it been since you did the trial on the Si? Overtime, based on what happened with the Apexi Neo, I would've thought the ECU would fight the programming of the CamCon, which is why I'm asking. Everything was fine at first with the Neo, but overtime, the stock ECU became more aggressive in trying to return it to a based tune. Are you saying this does not happen with the CamCon?
I should have that diagram for you in the next day or two. I checked with my contact and he's definitely able to get them both.
Old May 30, 2007 | 03:51 PM
fandirabbani08's Avatar
hey renton where are you located... are you in renton, wa?
mojackson2390
Aug 31, 2008 08:31 PM
ej2civic
Jun 18, 2007 07:32 AM
ComptonsF1NEST
Northeast (Sales)
Apr 24, 2006 08:55 AM
ahthisguyhere
Mar 8, 2006 04:22 PM
