Hondamonster's Rex build.
Old May 28, 2007 | 09:42 PM
Hondamonster's Avatar
Default Hondamonster's Rex build.
Ok, so it seems like everybody is doing a build thread, and i want in
i picked up my 88 crx hf 'shell' as kind of a rescue mission. the guy wanted 400 and i turned him down... until a few weeks later when he called and said "250 if you get it out of my driveway by the end of the week. if not, it gets crushed."
and thats how you sell me a honda. i trailered it home and started de-construction.
it had a crappy bright yellow paint job and didnt run. he said it was a distributor issue and had left said dizzy in a bag in the pass seat. i bolted it in and played with the wiring for about an hour and it ran... but only on two cylinders.
maybe bad compression? lol
the block had been swapped for a d15b7 for some reason, but its in good shape, so im going to use it for a mini-me since i already have most of the parts
So my work has begun!
heres my block. you can still see cross-hatching in person. no damage either
RICE!!!
The interior was NASTY. ripped it all out. (you can see the dizzy on the floorboard lol)
the front end didnt quite line up... it has been lightly wrecked
heres the engine bay. could use improvements...
heres some stripping to get to the frame. after 3 hours, 2 crow bars, a scissor jack, sledge hammer and a yard stick and a carpenters square, i got the frame straight.
I have a ton of work yet, but i also have a vision for this car! cant wait to see how it turns out
Modified by Hondamonster at 12:54 AM 5/29/2007
Old May 28, 2007 | 09:57 PM
added a couple pics, more to come
Old May 28, 2007 | 10:01 PM
low91rex's Avatar
Default Re: (Hondamonster)
Looking good so far, what are your plans for the exterior?
Old May 28, 2007 | 10:06 PM
Default Re: (low91rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low91rex &raquo;</TD></TR><TR><TD CLASS="quote">Looking good so far, what are your plans for the exterior?</TD></TR></TABLE>
needs new doors and hood (severe bondo on the doors and the hood has rice pins and led sprayers. im going to strip off all the paint (it used to be the gorgeous factory teal ) and primer the car for now, as my money is going under the hood
Old May 28, 2007 | 10:24 PM
HatchMo's Avatar
A looooot of work ahead of you. Good luck.
Old May 29, 2007 | 12:35 AM
89crxsiVT's Avatar
We'll looks pretty good for $250. I would of bought it too. I pick my civic dx up for $100.
We'll good luck, can't wait to see it done.
Old May 29, 2007 | 09:45 AM
Bserieskllr's Avatar
looks like that was a whole d15b7 becuase the hf only had 8 valves, just throwing that out there, nice project though check out mine if you get a chance(link is in my sig.)
88hf is the lightest ed/ef car
Old Jun 1, 2007 | 09:28 PM
Default update
progress has been slow due to work... but i finally got some time to work on the crx.
heres my z6 head about to be cleaned
valvetrain and cam cleaned up
i did a mild port polish with a dremel... turned out pretty nice, i think
head after a nice cleanup
exhaust valves back in...
then the intake valves...
followed by cam and valvetrain. im using all new gaskets and seals, so the cam seal was replaced (cam gears are hard to get off!) everything got a coat of clean oil before being put back together... now i need a torq wrench to put everything in spec torq... ill get more done tomorrow
Modified by Hondamonster at 12:38 AM 6/2/2007
Old Jul 24, 2007 | 07:37 PM
Default Re: update (Hondamonster)
ok ive been really busy lately, so heres an update
finished the head work
its all assembled in this one. every gasket and seal replaced, valve job, port grind and polish and i polished the intake manifold and painted the valve cover. i have to dump the pics off of my card to upload the new stuff... but the motor is together now and runs. i had exhaust put on the other day so now its actually street legal. and holy ***** that hf tranny sucks
NOFX
Dec 12, 2014 01:20 PM
bheinen74
36
Sep 8, 2014 08:05 AM
91sicrxer
33
Jun 13, 2005 09:44 PM
m3talc0re
Mar 1, 2005 10:17 AM
