NEED HELP ASAP!!! MY CAR HAS CODE: P1129
Old May 28, 2007 | 06:17 PM
TRYLSTEG808's Avatar
Default NEED HELP ASAP!!! MY CAR HAS CODE: P1129
i have a 99 Acura Integra LS (stock) I was cleaning my throttle body and after i put it back my CEL went on.
I had a friend ran a diagnostic on my car and the OBD scan reader showed " MAP HIGHER THAN EXPECTED CODE: P1129" My friend is not that much educated about Hondas neither do I.
Need to know what this code mean and what repair is needed. I dont want to go see a mechanic at first and give me nonesense repairs just to make money off my ***. I already had been through a bad experience with mechanics.
HELP ME OUT PLEASE
Old May 28, 2007 | 07:50 PM
eshlil's Avatar
Default Re: NEED HELP ASAP!!! MY CAR HAS CODE: P1129 (TRYLSTEG808)
delete the code and wait and see if it comes back, but as far as fixing the problem maybe a new map sensor but clear it first and see if it comes back.
Old May 28, 2007 | 08:26 PM
Default Re: NEED HELP ASAP!!! MY CAR HAS CODE: P1129 (eshlil)
THE CODE CAME BACK
Old May 28, 2007 | 09:03 PM
dtapia's Avatar
The scan tool indicates Diagnostic Trouble Code (DTC) P1128: Manifold Absolute Pressure (MAP) lower than
expected.
— The MIL has been reported on.
— DTC P1128 is stored.
Problem verification:
1. Turn the ignition switch ON (II).
2. Check the MAP with the scan
tool.
Is 54.1 kPa (406 mmHg, 16.0
in.Hg) or higher indicated?
Intermittent failure, system is OK
at this time.
The scan tool indicates Diagnostic Trouble Code (DTC) P1129: Manifold Absolute Pressure (MAP) higher than
expected.
at this time.
YES
Replace the MAP sensor.
NO
NO
Is 43.3 kPa (325 mmHg, 12.8 YES
in.Hg) or less indicated?
1. Start the engine. Hold the
engine at 3,000 rpm with no
load (in Park or neutral) until
the radiator fan comes on, then
let it idle.
tool.
— DTC P1129 is stored.
Old Jan 4, 2011 | 03:42 AM
GregWrench63's Avatar
I have a 1998 Honda Accord with a 2.3 . Just R&R'd the motor . Never had codes on old engine before timing belt went. New engine has DTC p1129 MAP pressure too high. R&R'd MAP . Still surges . I would like some help with this as it's becoming a pain and the obvious answers arent working.
rfm98crv
Honda CR-V & Element
Sep 2, 2013 05:08 AM
aptyk88
Oct 15, 2008 12:49 PM
saver
Mar 28, 2006 10:19 PM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
Flexmyrex
Aug 16, 2002 08:46 PM
